commodore.gen.trAmigaAmiga DonanımFlashFloppy yeni gotek firmware
Sayfa: 1 ... 7 8 [9] 10 11 ... 16   Aşağı git
Gönderen Konu: FlashFloppy yeni gotek firmware  (Okunma Sayısı 174102 defa)
Mesaj Sayısı: 2.754
« Yanıtla #120 : Eylül 26, 2019, 12:14:06 ÖS »
İkinci bir A500'üm olsa bunu yapardım ama HxC kullanmama rağmen halihazırda çok lüzumlu gelmedi..  (zaten external kullanıyorum ben..)
Mesaj Sayısı: 3.078
« Yanıtla #121 : Ekim 09, 2019, 22:49:11 ÖS »
 v3.5a (Experimental)
New Main Menu: Press Prev/Next or Select with no Flash drive inserted
Factory Reset, Firmware Update, OSD Config
OSD: Must be updated to latest version: v1.7 or later!
OSD: Receive Gotek button commands via I2C
OSD: Default to 40 columns if no other display is connected
TR-DOS (TRD): Fix geometry detection based on TR-DOS header
https://github.com/keirf/FlashFloppy/releases/download/v3.5a/flashfloppy-v3.5a.zip
https://github.com/keirf/FlashFloppy/releases/tag/v3.5a
« Son Düzenleme: Kasım 12, 2019, 16:02:22 ÖS Gönderen: Kaan Akkurt » Logged
Mesaj Sayısı: 3.078
« Yanıtla #122 : Ekim 13, 2019, 12:48:25 ÖS »
v3.6a (Experimental)
Quick Disk Initial Release (QD SYSTEMS ONLY)
New firmware and blank QD image in alt/quickdisk
Documentation in the Wiki
DO NOT RUN ON NORMAL FLOPPY SYSTEMS: QD ONLY
Please report any issues AND SUCCESSES!!
Update HxC Compat to v7-FF
Fix failure when booted on unmodded A1200 ESCOM boards
https://github.com/keirf/FlashFloppy/releases/download/v3.6a/flashfloppy-v3.6a.zip
https://github.com/keirf/FlashFloppy/releases/tag/v3.6a
« Son Düzenleme: Kasım 12, 2019, 16:02:12 ÖS Gönderen: Kaan Akkurt » Logged
Mesaj Sayısı: 3.078
« Yanıtla #123 : Kasım 11, 2019, 20:38:18 ÖS »
v3.7a (Experimental)
Release Notes:
Quick Disk Bug Fixes (QD Systems Only!!!)
Fix write offsets and lengths within QD track
Filter ADF images from navigator: only QD images supported
Extra logging in FFLOG.TXT for debug purposes
Amiga AutoSwap new title: Gobliiiins
Thanks to Arkadiusz Makarenko!
https://github.com/keirf/FF_AutoSwap/wiki/Downloads
https://github.com/keirf/FlashFloppy/releases/download/v3.7a/flashfloppy-v3.7a.zip
« Son Düzenleme: Kasım 12, 2019, 16:02:04 ÖS Gönderen: Kaan Akkurt » Logged
Mesaj Sayısı: 3.078
« Yanıtla #124 : Aralık 10, 2019, 22:29:09 ÖS »
v3.8a (Experimental)
USB: Fix buffer overflow when parsing string descriptors
Fixes crash with recent SanDisk Ultra Fit drives
HxC Compat, v8-FF: Fixes startup crash on Atari ST
Amiga: Fixes for "interface = amiga" setting
TR-DOS (TRD): Fix geometry when TR-DOS header is incomplete
Quick Disk: Larger read/write window in default blank image
GCC9 build fixes
https://github.com/keirf/FlashFloppy/releases/tag/v3.8a
https://github.com/keirf/FlashFloppy/releases/download/v3.8a/flashfloppy-v3.8a.zip
Mesaj Sayısı: 3.078
« Yanıtla #125 : Aralık 27, 2019, 22:20:25 ÖS »
v2.14 (Stable)
Release Notes:
IMG: Fix density-select pin output for HD images
Fixes 'pin02=dens' and 'interface=ibmpc-hdout'
Bug has existed since v2.2a
GCC9 build fixes
https://github.com/keirf/FlashFloppy/releases/download/v2.14/flashfloppy-v2.14.zip
v3.9a (Experimental)
Release Notes:
Rotary Encoder: Improve tracking
Higher frequency, and better debounce algorithm
https://github.com/keirf/FlashFloppy/releases/download/v3.9a/flashfloppy-v3.9a.zip
Mad_Wolf
Mesaj Sayısı: 255
« Yanıtla #126 : Aralık 28, 2019, 08:17:30 ÖÖ »
Merhaba beyler
cahilliğimi affedin ben bir Gotek sipariş verdim pc de kullanmak için fakat daha elime ulaşmadı.
Bu firmwareler tam olarak ne işe yarıyor acaba
Mesaj Sayısı: 3.078
« Yanıtla #127 : Aralık 28, 2019, 08:41:47 ÖÖ »
v3.10a (Experimental)
Release Notes:
Bootloader: Wait for buttons to be pressed then released...
...before starting firmware update process
Avoids an infinite loop when reprogramming Bootloader itself
https://github.com/keirf/FlashFloppy/releases/download/v3.10a/flashfloppy-v3.10a.zip
Mesaj Sayısı: 3.078
« Yanıtla #128 : Aralık 28, 2019, 08:49:05 ÖÖ »
Merhaba beyler
3.5" disket sürücüsü kullanabilen retro bilgisayarlarda gotek sürücüyü direk takıp kullanamıyoruz. Gotek içinde gelen orijinal yazılım bu bilgisayarlar ile uyumlu değil. Flashfloppy ile Atari - Amiga - ZX Spectrum - Amstrad gibi bilgisayarlarda gotek kullanılabilir hale geliyor.
Gotek sürücüye Flashfloppy firmware yükleme ve güncelleme ile iligli konu:
https://www.commodore.gen.tr/forum/index.php?topic=15104.0
Flashfloppy tarafından desteklenen platformlar
https://github.com/keirf/FlashFloppy/wiki/Host-Platforms
Mesaj Sayısı: 3.078
« Yanıtla #129 : Aralık 31, 2019, 12:48:49 ÖS »
v3.11a (Experimental)
LCD/OLED: Fix subfolder name, as shown in 3- & 4-row displays
Subfolder wasn't updated correctly when moving to parent (..) folder
https://github.com/keirf/FlashFloppy/releases/download/v3.11a/flashfloppy-v3.11a.zip
Mad_Wolf
Mesaj Sayısı: 255
« Yanıtla #130 : Ocak 15, 2020, 13:27:15 ÖS »
Beyler herkese merhaba
Pc'de kullanmak üzere bir adet gotek aldım
Nette bulduğum kaynaklardan batch manage tool v1.40 üzerinden flash belleğe format atılıp onun üzerinden disketlerin atılmasını tavsiye ediyorlar
Windows 10 kullanmaktayım tüm hakları vermeme rağmen format atmaya gittiğimde access is denied hatası alıyorum ve ne yaptıysam bir çözüm bulamadım
Mesaj Sayısı: 3.078
« Yanıtla #131 : Şubat 11, 2020, 08:28:25 ÖÖ »
v3.12a (Experimental)
IMG: Support IBM 3174 1.2M and 2.4M formats (host=ibm-3174)
HxC: Fix HxC mode with no file selector (AUTOBOOT.HFE)
FF OSD: Fix dual-display operation with slower OLED
Wait for OLED to initialise when display-type=oled...
https://github.com/keirf/FlashFloppy/releases/download/v3.12a/flashfloppy-v3.12a.zip
Mesaj Sayısı: 3.078
« Yanıtla #132 : Mart 13, 2020, 17:06:16 ÖS »
v3.13a (Experimental)
FF.CFG: New option write-drain=eot
Fixes writes to Gotek on Amstrad PPC series (#320)
FF.CFG: New option display-on-activity=sel
Turns on display whenever the Gotek drive is selected by host
HFE: Respect double-step header flag
Fixes 180k disk images on Amstrad PCW (#318)
https://github.com/keirf/FlashFloppy/releases/download/v3.13a/flashfloppy-v3.13a.zip
EMREZ
Mesaj Sayısı: 1.940
« Yanıtla #133 : Nisan 06, 2020, 19:27:52 ÖS »
F-F çok hızlı ilerliyor. Şuan hxc den farkı var mı? 10 Euro vermeye değer mi. Amiga için kullanılacak
this is amiga speaking.
Mesaj Sayısı: 1.731
İlla ki Amiga
« Yanıtla #134 : Nisan 06, 2020, 21:03:40 ÖS »
Bence hxc ye gerek yok. 10 Euronun üzerine bir 10 daha koyupbir gotek daha alırız.
Amiga 1200 + Vampire V1200
LG 24MA53 TVMonitör
Amiga 2000
2 Casper M989A Monitor
Commodore64
Sayfa: 1 ... 7 8 [9] 10 11 ... 16   Yukarı git
