commodore.gen.trAmigaAmiga DonanımFlashFloppy yeni gotek firmware
Sayfa: 1 ... 10 11 [12] 13 14 ... 16   Aşağı git
Gönderen Konu: FlashFloppy yeni gotek firmware  (Okunma Sayısı 186579 defa)
« Yanıtla #165 : Haziran 24, 2021, 17:18:47 ÖS »
v3.26 (Stable)
Support new Gotek board SFRKC30.AT4.7
https://github.com/keirf/FlashFloppy/releases/download/v3.26/flashfloppy-v3.26.zip
« Yanıtla #166 : Temmuz 02, 2021, 13:49:35 ÖS »
v3.27 (Stable)
Fix v3.26 regression in button handling for GOEX hardware (and other "Enhanced Gotek" models)
https://github.com/keirf/FlashFloppy/releases/download/v3.27/flashfloppy-v3.27.zip
EMREZ
Mesaj Sayısı: 1.938
« Yanıtla #167 : Temmuz 02, 2021, 13:54:28 ÖS »
HXC yi aratmıyor, helal olsun yapana sürekli üzerine çalışıyor.
this is amiga speaking.
Mesaj Sayısı: 2.751
« Yanıtla #168 : Temmuz 02, 2021, 14:56:25 ÖS »
Bir adet HxC Gotek'im var, Amiga ile kullanıyorum.  Açıkçası aralarında kayda değer bir fark kalmadı diyebilirim.
« Yanıtla #169 : Temmuz 26, 2021, 17:56:26 ÖS »
v3.28 (Stable)
Gotek model SFR1M44-U100LQD: Fix occasional rotary encoder issue
This model uses SFRKC40.AT4.7 PCB with encoder on new pin header
Rotary encoder would occasionally not be detected at power on
https://github.com/keirf/FlashFloppy/releases/download/v3.28/flashfloppy-v3.28.zip
« Yanıtla #170 : Temmuz 29, 2021, 17:22:16 ÖS »
FF OSD v1.9
Support AT32F403 chip as alternative to STM32F103
Support momentary-action hotkeys
https://github.com/keirf/FF_OSD/releases/download/v1.9/FF_OSD-v1.9.zip
Program an STM32 board
https://github.com/keirf/FF_OSD/wiki/Firmware-Programming
Connect FF OSD to your host machine and Gotek
https://github.com/keirf/FF_OSD/wiki/Hardware-Connections
Configure FF OSD
https://github.com/keirf/FF_OSD/wiki/Configuring-FF-OSD
« Yanıtla #171 : Ağustos 10, 2021, 17:47:44 ÖS »
FlashFloppy Pre-Release v4.0a (Experimental)
https://github.com/keirf/FlashFloppy/wiki/Downloads
New asynchonous I/O handling (Eric Anderson / ejona86)
Hard sector HFE image support (Eric Anderson / ejona86)
WARNING: This is an experimental release to gather testing feedback for the new async-I/O data path. It is not suitable for general use, nor for flashing onto Goteks intended for resale!
« Yanıtla #172 : Ağustos 10, 2021, 18:42:19 ÖS »
teşekkür ederim hemen yüklüyorum
« Yanıtla #173 : Ağustos 10, 2021, 18:46:32 ÖS »
bu deneysel sürüm, günlük kullandığınız gotek sürücülere yüklemeyin. Sadece deneysel özellikleri test etmek istiyorsanız kullanın. Konuyu paylaşan ben ve firmware yi yazan keirf gotek sürücünüzün çalışmaz hale gelmesinden sorumlu değiliz
« Yanıtla #174 : Ekim 02, 2021, 14:10:16 ÖS »
FlashFloppy Release v3.29
Support new Gotek board SFRKC30.AT2 using AT32F415KBU7-4 (QFN32)
Support LQFP64 AT32F415RxT7 chips on existing "Enhanced Gotek" boards
IMG: Fix default GAP2 for ED (eg. 2.88M) images
IMG.CFG: New parameter gap2= to set Post-ID Gap value
« Yanıtla #175 : Ekim 02, 2021, 14:11:27 ÖS »
v4.1a (Experimental)
Contains fixes/features up to v3.29 from v3 stable release series
Do not use index_suppressed if starting rd DMA is slow
ringio: Do not lose write for unaligned wd_prod
hfe: Protect HFEv3 against a broken run of 1s
blackturk
Mesaj Sayısı: 1.285
« Yanıtla #176 : Ekim 02, 2021, 14:23:07 ÖS »
 Ohaaa. Yine mi ?   Ben daha v3.25  yeni  yüklemiştim.
« Yanıtla #177 : Ekim 02, 2021, 15:38:16 ÖS »
Adamlar çalışıyorlar 😂😂
« Son Düzenleme: Ekim 02, 2021, 18:53:45 ÖS Gönderen: Özgür Dereli » Logged
fakcakaya
Mesaj Sayısı: 866
« Yanıtla #178 : Ekim 02, 2021, 16:04:12 ÖS »
en son kararlı sürüm hangisi şu anda? ve update yapmalımıyız
« Yanıtla #179 : Ekim 02, 2021, 16:13:41 ÖS »
son sürüm 3.29
update zorunlu değil. Her güncellemede Yeni özellikler ekleniyor. Tek tek sürüm notlarını inceleyip karar verebilirsin. İhtiyaç ise güncellersin.
Sayfa: 1 ... 10 11 [12] 13 14 ... 16   Yukarı git
