Gönderen Konu: PS4 Emulatör Var mı?  (Okunma Sayısı 1148 defa)
sait
Mesaj Sayısı: 483
« : Mayıs 25, 2018, 07:24:34 ÖÖ »
Ortalıkta PCSX4 diye bir PS4 emulatör var.KOF 14' çalıştırdığını belirtiyor.
Donanım Gereksinimi
PCSX4 requires a GPU to support at least Direct 3D 11.1 and Pixel shader model 5.0.
Nvidia: GeForce GTX 660 or higher is required.
AMD: AMD Radeon 7870 or higher is required.
To run every game smoothly @60FPS with 1080p resolution, GeForce GTX 970 or Radeon R9-290X can be recommended. PCSX4 does support 4K resolution but it is very difficult to reach 60FPS even with dual high-end GPU’s.
PCSX4 is optimized to use up to 8 cores of a processor but requires at least 4 core processor with SSE-4.2 and AVX.
Intel: Core-i5 3xxx and later is supported.
AMD: FX-41xx and later is supported.
CPU performance and stability with PCSX4 differs drastically and it is difficult to tell which processor works perfectly. Some mobile based i5 and i7 processors may cause performance glitches due to lower clock rates.
4GB is a minimum requirement for PCSX4 but 6GB or more is recommended. RAM with higher clock rates may increase game loading times when used together with the SSD as game cache disk.
« Son Düzenleme: Mayıs 25, 2018, 07:26:13 ÖÖ Gönderen: sait » Logged
SkyLord
Mesaj Sayısı: 37
« Yanıtla #1 : Mayıs 25, 2018, 07:27:55 ÖÖ »
Bildiğim kadarı ile ps4 ile pc mimari aynı. Emülatör varmı yok mu bilmem ama  ps3 emülatörüne göre daha kolay yapılır herhalde
Mesaj Sayısı: 1.060
« Yanıtla #2 : Mayıs 25, 2018, 08:10:19 ÖÖ »
Can I run pirated games?
No, there is no way you can run pirated games, PCSX4 is made in such a way that game cache-image (GCI) is encrypted with 256-bit header with .pdix hash which is linked to your PCSX4 account so dumped images are useless. We have a strict policy about piracy, please buy original games and support their developers.
Why my PCSX4 account is banned?
PCSX4 account stores unique Machine-id and PDIX for each account, if our system detects any illegal activity, your account and ip-address will be permanently banned from our servers.
PS4'e ve oyuna sahip değilseniz bu iş yaş gibi.
sait
Mesaj Sayısı: 483
« Yanıtla #3 : Mayıs 25, 2018, 08:15:56 ÖÖ »
Galiba PS4  oyunlarını şu an PC de oynamak mümkün değil.Zaten adam emulatörü parayla satıyor.Emulatör sahte olabilir.
Mesaj Sayısı: 1.060
« Yanıtla #4 : Mayıs 25, 2018, 09:00:42 ÖÖ »
PS emulatör ve hack işlerinde çok fazla çoluk çocuk var, dolayısı ile hile hurdada çok var.
Geçen sene PS3 hack işlerine bakmıştım okuduğum sözde rehberlerin hemen hepsi "10 sn gözümü kıstım, 5 kere x tuşuna bastım oldu" şeklinde saçma sapan şeylerdi.
Ne zamanki PS2 gibi kolay hale gelir o zaman tekrar bakarım şimdilik sarf edilen vakte ve emeğe değmez bence.
