Gönderen Konu: GURU KODLARI  (Okunma Sayısı 4044 defa)
tabu
Mesaj Sayısı: 1.005
« : Nisan 07, 2008, 01:25:56 ÖÖ »
A:Subsystem ID codes (if the number begins with 8 it is a non-recoverablecode, hence the system goes down - as I'm sure you're all aware). These tell you where the error occurred:
00-CPU Exception 01-Exec library
02-Graphics library 03-Layers Library
04-Intuition Library 05-Maths Library
07-Dos Library 08-RAMLIB library
09-Icon Library 0A-Expansion Library
0B-Diskfont library 10-Audio device
11-Console device 12-Gameport device
13-Keyboard device 14-Trackdisk device
15-Timer device 20-CIA resource
21-Disk resource 22-Misc resource
30-Bootstrap 31-Workbench
32-Diskcopy 33-Gadtools
34-Utility library 35-Unknown
B:General Error Codes:
01-Not enough memory 02-couldn't make library
03-can't open library 04-can't open device
05-can't open resource 06-I/O error
07-No signal 08-Bad parameters
09-close library failed; usually too many closes
0A-close device failed; or a mismatched close
0B-Process creation failed
C:Specific Alert Codes
-Exec Library:
0001-68000 exception vector checksum (obs)
0002-exec checksum bad (obs)
0003-library checksum failure
0005-corrupt memory list detected in FreeMem
0006-No memory for interrupt servers
0007-InitStruct() of an APTR source (obs)
0008-A semaphore is in an illegal state at Rem Semaphore()
0009-Freeing memory that is already free
000A-Illegal 68k exception taken (obs)
000B-attempt to reuse active OIRequest
000C-Sanity check on memory list failed during AvailMem (MEMF_LARGEST)
000D-IO attempted on closed IORequest
000E-Stack appears to extend out of range
000F-Memory header not located. Usually an invalid address passed to FreeMem
0010-An attempt was made to use the old message sephamores
00FF-A quick interrupt has happened to an uninitialised vector
-CPU Exceptions:
0002-Bus Error 0003-Addressing error
0004-Illegal instruction 0005-divide by zero
0006-CHK instruction 0007-TRAPV instruction
0008-Privilege violation 0009-Trace
000A-OpCode 1010 000B-OpCode 1111
000E-Stack frame format error
0018-spurious interrupt error
0019 to 001F-Autovector Level 1 to 7 int error
-Intuition Library:
0001-unknown gadget type
0002-create port, no memory
0003-item plane alloc, no memory
0004-Sub alloc, no memory
0005-Plane alloc, no memory
0006-Item box top <RelZero>
0007-Open screen, no memory
0008-open screen, raster alloc, no memory
0009-Open sys screen, unknown type
000A-Add SW gadgets, no memory
000B-Open window, no memory
000C-Bad Stare Return entering intuition
000D-Bad message recieved by IDCMP
000E-Weird echo causing incomprehension
000F-Couldn't open the Console Device
0010-Intuition skipped obtaineding a sem
0011-Intuition obtained a sem in bad order
-Graphics Library:
0000-graphics out of memory
0001-MonitorSpec alloc, no memory
0006-Long frame, no memory
0007-short frame, no memory
0009-text, no memory for TmpRas
000A-BltBitMap, no memory
000B-regions, memory not available
0030-Make V Por, no memory
000C-(GFX New Error)
000D-(GFX Free Error)
1234-Emergency memory not available
0401-Unsupported font description used
-Workbench:
0000-no fonts
0001-Workbench (WB) bad startup Msg1
0002-WB bad startup Msg2
0003-WB bad IO Msg
0004-WB Init Potion Alloc Drawer
0005-WB Create WB Menus Create Menus1
0006-WB Create WB Menus Create Menus2
0007-WB layout WB Menus layout Menus2
0008-WB Add Tool Menu Item
000A-WB InitTimer
000B-WB Init Layer Demon
000C-WB Init WB Gels
000D-WB Init Screen and Windows1
000E-WB Init Screen and Windows2
000F-WB Init Screen and Windows3
0010-WBMAlloc
-Layers Library:
0000-Layers out of memory
-Expansion Library:
0001-Freed free memory
-Trackdisk Device:
0001-Calibrate: seek error
0002-Delay: error on timer wait
-Disk Resource:
0001-Get unit: already has a disk
0002-Interrupt: no active unit
-RamLib Library:
0001-Overlays are Illegal for library segments
-Console Device:
0001-Console can't open initial window
-Timer Device:
0001-Bad request
0002-Power supply: no 50/60 Hz ticks
-Bootstrap:
0001-Boot code returned an error
-Dos Library:
0001-No memory at startup
0002-EndTask didn't
0003-Qpkt failure
0004-Unexpected packet recieved
0005-Freevec failed
0006-Disk block sequence error
0007-Bitmap corrupt
0008-Key already free
0009-Invalid checksum
000A-Disk error
000B-Key out of range
000C-Bad overlay
000D-Invalid init packet for CLI/Shell
000E-A filehandle was closed more than once
-Alert Objects:
8001-ExecLib 8002-GraphicsLib
8003-LayersLib 8004-Intuition
8005-mathLib 8006-DOSLib
8008-RAMLib 8009-IconLib
800A-ExpansionLib 800B-DiskfontLib
800C-UtilityLib 800D-KeyMapLib
8010-AudioDev 8011-ConsoleDev
8012-GameportDev 8013-KeyboardDev
8014-TrackDiskDev 8015-TimerDev
8020-CIARsrc 8021-DiskRsrc
8022-Miscrsrc 8030-Bootstrap
8031-Workbench 8032-Diskcopy
8033-GadTools 8035-Unknown
DevilisH
Mesaj Sayısı: 1.163
aLWaYs AmigA
« Yanıtla #1 : Nisan 08, 2008, 22:19:22 ÖS »
Emeğine sağlık üstadım
Gokhan Ozkan
Mesaj Sayısı: 2.269
« Yanıtla #2 : Nisan 09, 2008, 14:44:25 ÖS »
Çok sağol . Çok iyi oldu
