Gönderen Konu: Ayfly v0.0.25 (ses işlemcisi emülatörü)  (Okunma Sayısı 4048 defa)
Alcofribas
Mesaj Sayısı: 986
Who Dares Wins!
« : Mart 08, 2009, 20:35:12 ÖS »
Ayfly, retro dünyasının SID kadar başarılı olmasa bile pek çok cihazda tercih edilen meşhur AY-891x serisi ses işlemcisini emüle eden başarılı bir yazılım.
Şu an için desteklediği işletim sistemleri: Linux, Windows, Symbian 8,9 ve UIQ3.
Windows CE'nin ise desteklenmesi düşünülüyor(muş).
Şu linkte de AY-891x hakkında epey bir örnek, emu, açıklama var. Hatta bu işlemci konusunda daha derli toplu bir sayfa görmedim diyebilirim.
Ve işte bu da gelişim evreleri
Changelog:
28.02.2008 - 0.0.25
YM format support added
Fixed bug in PT3_GetTime function - now time for pt3 modules calculated correctly
Added ayfly_fym_convertor project for converting modules to FYM AY player written in flashbt SAGE studio.
Some bug fixes
Ayfly library: added 2 functions ay_setaywritecallback to trace writes to ay chip and ay_ists to determine if current module uses 2xay mode.
New icon. Thx 2 mmcm.
11.01.2008 - 0.0.24
Rewritten PT2 player in c++. Now the only emulated format is .AY
Added beeper emulation support
Improved z80 emulation in Symbian versions
Added full z80 emulation for Symbian builds
02.01.2008 - 0.0.23
Rewritten STP and STC player in c++
Symbian version speedups
Compiled symbian 8 version
15.12.2008 - 0.0.22
Added filtering and oversampling to ay synth in pc version
AY synth moved to integers in symbian versions
Removed filtering in symbian versions for more efficiency
Improoved Directx driver stability
Added ay_dumper programm for converting ay modules to register data
+ a lot of small optimizations
10.10.2008 - 0.0.21
Turbo sound support added
Digital AY support added
ay code optimized
Content detector added
ayfly_converter is now able to read from stdin and change sample rate
Metadata (Name and Author) support added
Symbian version optimized
Multiple sample rates support in libayfly added
24.10.2008 - 0.0.20
Minor changes:
Removed wxWidgets and SDK(Directx under Windows) dependency for building only library and converter
Added command line parsing code
Added ability for selection of multiple files in open dialog
21.10.2008 - 0.0.19
Added support for VTX format
Added ayfly_converter program
26.09.2008 - 0.0.18
Added basic playlist to S60 version
Updated z80ex library to latest version (thx 2 boo_boo)
DirectX driver is more stable now. Windows versions now use it instead of WaveAPI.
+Improoved stability on Windows Vista
Made mingw32 makefiles for building ayfly.dll library without Visual Studio (and even Windows)
Added first version of library API documentation
Fixed some bugs
06.09.2008 - 0.0.17
Added support for PT1 format
PT3 player rewritten in c++
Added YM emulation
Fixed some bugs in symbian version
Added S60 2nd (Symbian Karizmatik build
Added UIQ3 build
Changed default windows audio driver from DirectX to Wave API
Made ANSI library version for windows
Removed ayfly_dynamicdll.h because of inconsistency with ayfly.h
Fixed bugs
24.08.2008 - 0.0.16
Added support for PSG format
Some optimizations in AY emulator
Symbian player rewritten to be more stable. Now using CMdaOutputStream interface
Added library - libayfly with clean interface
Added library usage example for Windows - ayfly_cmdline
DLL ayfly.dll is ready to be used in 3rd party applications
Added ability to add folders in playlist
Added sliders in ayfly application to change interrupts and AY frequency
A lot of bugs fixed
All functions rewritten to use c++ standard library
06.08.2008 - 0.0.15
New formats supported: SQT and PSC
Fixed bugs in AY emulator
AY emulator code is now the same on PC and Symbian builds
01.08.2008 - 0.0.14
Added filters for synth signal in symbian build
Volume on Symbian can now be changed with up an down arrows
Added ASC Sound Master player
Initial work began for moving player core to the library
30.07.2008 - 0.0.13
Make Symbian build work on 220x ARM processors. Defaults now are: 32Khz, stereo
Fixed z80 interrupt time
Fixed case sensivity in filename parsing
Minor bugs fixed
25.07.2008 - 0.0.12
Added key bindings dialog (no editing yet)
Probably fixed DXAudio driver
All bingings work now
Fixed small bugs as usual
24.07.2008 - 0.0.11
Added initial support for key bindings (default is winamp style)
Fixed bugs
22.07.2008 - 0.0.10
Fixed bugs in DXAudio.
README rewrited
19.07.2008 - 0.0.9
Implemented position slider.
17.07.2008 - 0.0.8
Added time functions for stc, stp, ay, pt3 and pt2 formats - thanks to ay_emul sources!
11.06.2008 - 0.0.7
Initial playlist (without song's length yet)
Removed menu bar.
07.06.2008 - 0.0.6:
Fixed some bugs in ay emulator.
Updated "About" dialog.
0.0.5:
Added volume sliders for all channels with link button.
Fixed some bugs.
0.0.4:
Added time counter.
Added volume slider.
0.0.3:
Added default icon set by Alexander Shatin.
Fixed minor bugs.
0.0.2:
Added iir low-pass filter + oversampling to ay emulator in order to remove ring modulation and alising on high notes.
Added ability to mute any of 3 channels while playing.
All icons are now 32x32 pixels in size.
Added drag'n'drop. Works both in Linux and Windows.
0.0.1: Initial release.
hakanzade
« Yanıtla #1 : Mart 09, 2009, 00:31:23 ÖÖ »
peki bunun High Voltage kolleksiyonu varmı.
