Sayfa: [1] 2 3   Aşağı git
Gönderen Konu: Natami MX Board  (Okunma Sayısı 29498 defa)
Blasterreal
Mesaj Sayısı: 856
« : Şubat 13, 2011, 17:25:36 ÖS »
Natami MX Board için yeni görseller yayınlandı oldukça güzel duruyor. Eger çıkar ise Amiga Dünyasına büyük bir damga vuracagına eminim. Umut veren güzel bir proje.
http://www.natami.net/gfx/NatAmi64_MX/natami64_mx_1.jpg
http://www.natami.net/gfx/NatAmi64_MX/natami64_mx_2.jpg
http://www.natami.net/gfx/NatAmi64_MX/natami64_mx_3.jpg
http://www.natami.net/gfx/NatAmi64_MX/natami64_mx_4.jpg
http://www.natami.net/gfx/NatAmi64_MX/natami64_mx_5.jpg
http://www.natami.net/gfx/NatAmi64_MX/natami64_mx_6.jpg
Teknik Detayları;
-Altera FPGA from the Cyclone IV-series, containing the enhanced Amiga chipset "SuperAGA" as well as other system logic, and the brand new 68k CPU design "N68050"
-512 MB DDR2 SDRAM (onboard)
-1x PCI slot, expandable to 3x PCI with a PCI riser
-"SyncZorro" expansion slot, for adding f.e. a CPU card (68060 card will be available as an option for this slot)
-DVI-I port for 31kHz video (one can connect both analog VGA and digital DVI), scandoubling function for legacy modes
-15kHz RGB-output/input expansion slot (for optional 15kHz card)
-Realtek RTL8110 Gigabit Ethernet
-NEC USB2 controller and USB ports
-3,5 inch IDE port
-Internal Compact Flash connector (IDE)
-Kickstart flash memory
-Floppy connector (Amiga and PC drives both usable)
-Amiga serial port (although reduced to 9-pin)
-Amiga parallel port
-2x Amiga-joystick/mouse port
-4x Cinch/RCA connectors for stereo sound output and input
-PS/2 keyboard/mouse ports (old bigbox Amiga keyboards are connectable)
-Classic Amiga LED:s along with scandoubler LED
Resim ve daha fazla bilgi için;
http://www.natami.net/hardware.htm
Board üzerinde tam olarak tamamlanmamış soketler var burdan görebilirsiniz;
Amiga 1200
Amiga OS 3.9
Morphos 3.9
Mesaj Sayısı: 11.418
« Yanıtla #1 : Şubat 13, 2011, 17:36:19 ÖS »
Bana heycan veren tek proje Natami... Ama bu tür projelerin geliştirmesi çok uzun sürüyor...Ömrümüz yeter umarım...
« Yanıtla #2 : Şubat 13, 2011, 19:17:57 ÖS »
bakalım ne zaman satışa çıkacak
Blasterreal
Mesaj Sayısı: 856
« Yanıtla #3 : Şubat 13, 2011, 23:44:15 ÖS »
özkan bu lafı kullandıysa bilinki piyasadaki tüm natamileri toplayacak
Amiga 1200
Amiga OS 3.9
Morphos 3.9
« Yanıtla #4 : Şubat 14, 2011, 08:06:54 ÖÖ »
nerden çıkardın serkan
Blasterreal
Mesaj Sayısı: 856
« Yanıtla #5 : Nisan 29, 2011, 23:29:55 ÖS »
Natami ile ilgili yeni resimler gün yüzüne çıkmaya başladı.
####################### D A Y 1 #######################
####################### D A Y 2 #######################
Amiga 1200
Amiga OS 3.9
Morphos 3.9
hakdead
Mesaj Sayısı: 818
« Yanıtla #6 : Nisan 29, 2011, 23:46:37 ÖS »
hadi bakalım hayırlısı ne olacak sonu
Mesaj Sayısı: 4.785
« Yanıtla #7 : Nisan 30, 2011, 09:36:41 ÖÖ »
İşte şimdi heyacanlanmaya başladım. Zannetmiyorum ama umarım makul bir fiyatı olur.
atlantis
Mesaj Sayısı: 2.117
« Yanıtla #8 : Nisan 30, 2011, 10:34:57 ÖÖ »
Chameleon64'den daha ucuz olmaz sanırım.
Truva Linux
http://www.truvalinux.org.tr
http://retromiga.blogspot.com
https://www.bananapi.gen.tr
« Yanıtla #9 : Nisan 30, 2011, 10:45:47 ÖÖ »
en z 500$ olur
Blasterreal
Mesaj Sayısı: 856
« Yanıtla #10 : Nisan 30, 2011, 15:04:22 ÖS »
####################### D A Y 3 #######################
Evet birazda Natami oyunları görselleri paylaşalım gördüğüm kadarı ile gayet başarılı yarın internet bağlantısı ve biraz daha oyun.
Amiga 1200
Amiga OS 3.9
Morphos 3.9
Blasterreal
Mesaj Sayısı: 856
« Yanıtla #11 : Mayıs 01, 2011, 23:46:29 ÖS »
####################### D A Y 4 #######################
Amiga 1200
Amiga OS 3.9
Morphos 3.9
« Yanıtla #12 : Mayıs 02, 2011, 09:18:04 ÖÖ »
dunyanın en genç amiga beta tester ı
« Yanıtla #13 : Mayıs 02, 2011, 09:19:18 ÖÖ »
yanlız şuana kadar görduklerimizin hepsi minimig de olan özellikler asıl natami nin yeni aga sını destekelyen demolar olsa daha iyi fikir verecek
« Yanıtla #14 : Mayıs 02, 2011, 10:48:14 ÖÖ »
Yeni AGA destekleyen bir oyun yapılıyordu. Hatta ben bayağ bir model yapıp yollamıştım...Ama sonra ilgilenemedim. Öyle kaldı. Shootem'up türü bişeyler olması lazım... Yakında onlarıda görürüz...
Sayfa: [1] 2 3   Yukarı git
