commodore.gen.trArcade Sistemler ve Oyun KonsollarıOyun KonsollarıSega Saturn artık mod çipsiz backup oyun çalıştırabiliyor
Gönderen Konu: Sega Saturn artık mod çipsiz backup oyun çalıştırabiliyor  (Okunma Sayısı 8630 defa)
« : Temmuz 09, 2014, 23:13:18 ÖS »
http://www.assemblergames.com/forums/showthread.php?52526-Saturn-proof-of-concept-bootloader-Pseudo-Saturn
Install Instructions
Requirements: Installation requires you to own an Action Replay(ideally EMS) and a method for flashing data to the Action Replay. The default
installer is via cd image, which requires you to burn and boot the disc on the Saturn, which requires a blank cd, and modchip or disc swapping which won't
be covered here.
WARNING: Flashing data to your Action Replay may possibly fail. This is especially true on Saturn's with old and/or faulty cartridge connectors. If your Saturn has a history of corrupted saves or cheats it's quite possible flashing will fail and your Action Replay will be bricked.
1. Burn installer.iso to a cd
2. Boot Saturn and let CD load
3. Select "Backup AR to Commlink" (Optional)
4. Use a utility designed for your commlink and download memory addresses 0x00200000-0x00240000. When finished go back to menu. (Optional)
5. Select "Inst Firmware from Disc".
6. When ready hit buttons A+B+C.
7. Wait for firmware install to finish. DO NOT TURN OFF SYSTEM. It may take a few minutes.
8. You should see a "SUCCESS" message if all goes well. Press reset to enjoy your new firmware!
Usage Instruction
1. First you need to patch an existing disc image using "cdpatch" utility. Currently only iso and bin/cue formats are supported.
2. Start up appliation. Click "Browse" and select image.
3. Click "Patch".
4. Close application and load up your favorite cd burning software and burn to CD.
5. Make sure your Action Replay is inserted while the Saturn is off.
6. Turn on Saturn and go through boot process. License screen should pop up, and then a new menu should show.
7. Use d-pad to move selection. By default it should be over "Start Game". Make sure it's selected and press 'A' button.
8. If all goes well, game should be detected as a "Pseudo Saturn" disc and boot up. Retail discs should also boot fine.
Todo List
There's a few things I really want to add at some point given the time:
-Clean up code and improve build setup.
-Cheats support like stock Action Replay software
-Saves support of some sort like stock action replay. Ideally I'd like to hook into the bios's save functions so it can save directly to the cart.
-More debug functionality for developers.
-A better looking menu
Special Thanks
Thanks to my buds on #yabause and rhdn
-Amon
-Bacon
-BlueCrab
-cafe-alpha
-Charles MacDonald
-esperknight
-Guill
-pinchy
-SamIAm
-SaturnAR
-tehcloud
-WhiteSnake
The "Screw you" list(by request)
-KrossX
-vbt
segaa
Mesaj Sayısı: 1.524
« Yanıtla #1 : Temmuz 10, 2014, 00:11:33 ÖÖ »
Süper konu da keşke Türkçe anlatım olsaydı
mesa
Mesaj Sayısı: 868
« Yanıtla #2 : Temmuz 10, 2014, 01:24:22 ÖÖ »
be covered here.
Usage Instruction
3. Click "Patch".
Todo List
Special Thanks
-Amon
-Bacon
-BlueCrab
-cafe-alpha
-Charles MacDonald
-esperknight
-Guill
-pinchy
-SamIAm
-SaturnAR
-tehcloud
-WhiteSnake
-KrossX
-vbt
Denedinmi hic kopya oyun?
Mesaj Sayısı: 11.418
« Yanıtla #3 : Temmuz 10, 2014, 11:54:23 ÖÖ »
Güzel bir gelişme...ama bana çok pratik gelmedi Çipli Saturn'e sahip olduğum için sanırım...
Saturn Diskleri okunur ilk sektöre gidip belli bir dizinin olup olmadığına bakıyor. Eğer 16 baytlık ilk dizi "SEGA SEGASATURN"'e sahipse okuyor... Bunu değiştirmiş arkadaş. İlk sektöre farklı bilgi yazıyor. Bu sefer, boot loader'ı değiştirmek gerekiyor. Bunu da Action Reply kartuşunu (buna ihtiyacınız var) modifiye ederek yapıyor...
Kısaca, modifiye edilmiş Action Reply kartuşu ve modifiye edilip yazılmış oyun CD'sine ihtiyacınız var...(anladığım kadarıyla)
« Yanıtla #4 : Temmuz 10, 2014, 12:02:49 ÖS »
evet lw3d ninin dediği gibi sistem
ihtiyacımız olan cihazlar
1. Sega Saturn
2. Action Replay
indirdiğimiz dosyadan çıkan iso yu bir cd ye yazıyoruz
ilk başta bir çipli bir saturn buluyorsunuz yada swap yontemiyle bir defaya mahsuz yazdığımız cd ile action replay i flash lıyoruz
yine aynı pakette bulunan patch ile iso ları patchleyip yazıyoruz
artık çipli saturn e ihtiyaç duymadan action reply ile oyunları oynuyabiliyoruz
segaa
Mesaj Sayısı: 1.524
« Yanıtla #5 : Temmuz 10, 2014, 14:34:52 ÖS »
Bence de hiç pratik değil, bu kadar uğraştıktan sonra...
AmonR
Mesaj Sayısı: 502
« Yanıtla #6 : Temmuz 10, 2014, 14:52:21 ÖS »
Chipli Saturn'ü olmayan ama Action Replay kartuşu olanlar için güzel bir imkan.
(Tabii bir de chipli Satur'ü olan bir arkadaşınız olmalı veya "swap trick" yapabiliyor olmalısınız.)
Sinclair: ZX Spectrum +2
Sega: Saturn, Dreamcast
Microsoft: XBOX
Sony: PS1, PSP ve sonunda PS2
reprep
Mesaj Sayısı: 28
« Yanıtla #7 : Temmuz 19, 2014, 22:33:43 ÖS »
her zaman hayalini kurduğum bir şeydi. çipli saturn aldığım için şu an çok ilgimi çekmiyor ama saturn çiplerinin az bulunduğu göz önüne alındığında güzel bir haber.
swap trick zor bir şey değil, sadece ems kartuş yeterli yani. ems kartuş da 50-100 tl aralığında bulunabiliyor. zaten bu işlem için olmasa bile ems kartuş çok gerekli. benim saturnumde hep takılı duruyor.
AmonR
Mesaj Sayısı: 502
« Yanıtla #8 : Temmuz 21, 2014, 10:44:52 ÖÖ »
Yalnız anladığım kadarıyla EMS (Action Replay) kartuşun firmware'ini flashladığınızda artık asıl özellikleri (game save, cheat) kullanılamıyor. (En azından şimdilik durum böyle)
O sebeple ikinci bir EMS kartuş bulundurmakta fayda var.
Microsoft: XBOX
« Yanıtla #9 : Ocak 20, 2019, 22:38:38 ÖS »
Pseudo Saturn Kai kullanarak elimdeki Saturn Action Replay kartuşlarını flashladım.  Pseudo Saturn Kai için yukarıda "pek pratik değil yazmışım" ama backup oyun oynatmak için sanırm şu andaki en pratik yöntemlerden bir tanesi.. Çip bulmanın zorluğu, bulunsa uygulama sıkıntılarını düşününce, kartuş sayesinde backup oyun oynatmak ve hatta bölge sınıraması olmadan bunu yapmak fena fikir değil (çipli sistemde ST-Key kartuşuyla ya da donanımsal hack ile bölge sorunu aşılıyordu sanırım). Hatta ilk yayınlanmasından bu yana oldukça da gelişme kayıt edilmiş...
@AmonR ilk çıktığında başaramıyordu, ama yeni sürümlerde bunu başarabiliyorlar. Hatta install'da yer alan cheatcode'ları kullanmakta mümkünmüş (denemedim).
http://ppcenter.webou.net/pskai/
« Son Düzenleme: Ocak 20, 2019, 22:42:50 ÖS Gönderen: LW3D » Logged
