commodore.gen.trArcade Sistemler ve Oyun KonsollarıOyun Konsolları XStation : Playstation için Optical Discdrive Emulator
Gönderen Konu: XStation : Playstation için Optical Discdrive Emulator  (Okunma Sayısı 2534 defa)
Mesaj Sayısı: 11.086
« : Ağustos 05, 2020, 21:29:03 ÖS »
Playstation için düzgün görünen ve %100 uyumlu olduğu söylenen Optik Okuyucu Emulatörü... Önsipariş bitmiş ama oldukça iyi görünüyor...
https://castlemaniagames.com/products/xstation
Compatibility:
The XStation can be installed in SCPH-100x, SCPH-5xxx and some SCPH-700x series consoles. Specifically, motherboard models that are supported are: - PU-7 - PU-8 - PU-18
    Early SCPH-700x models come with either a PU-18 or PU-20 motherboard. Please check before purchasing. PU-20 is NOT supported.
    Net Yaroze and other special models are potentially compatible but have not been tested.
Launch Features
    100% compatibility with the PlayStation 1 library.
    Full Redump drag and drop support
    Multi-disc support and easy swapping
    Return to the Loader by holding the reset button for 1 second
    PS1Digital Compatibility and IGR support through PS1Digital’s OSD menu
    microSD cards of any size are supported
    ExFAT and FAT32 support
    Simple drag and drop card setup
    Supports .iso, ccd/img, cue/bin (single and multiple)
    Integrated PSNee, for automatic region-free operation
    Automatic 50/60Hz switching
    Loading times are similar to an original drive in good condition. You may notice slightly faster loading times due to reduced seek times while loading
    Easy firmware updates by simply dragging and dropping an update file to your microSD card.
    No registration necessary for updates, ability to revert to a previous firmware.
Upcoming Features
    Over-the-air updates with the use of the integrated Wi-Fi module
    Selective dither enable/disable per game on-the-fly
    Further use of the wireless capabilities possible
    Refreshed Loader GUI (planned to be overhauled)
Feandreu
Mesaj Sayısı: 341
« Yanıtla #1 : Ağustos 05, 2020, 21:53:57 ÖS »
Umarim fiyati biraz uygun olur, en azindan psio gibi olmaz.
Birilerinin psx ve ps2 ile hala ugrastigini gorunce cok seviniyorum.
Mesaj Sayısı: 6.625
love is better than
« Yanıtla #2 : Ağustos 05, 2020, 22:35:02 ÖS »
Güzelmiş Out of Stock. Bunun yerine bir playsation classic alıp hecklemek daha mantıklı abi sanki. Oda tam kırılmak için yapılmış mübarek Benimki hala yatıyor. Kahkaha
« Yanıtla #3 : Ağustos 05, 2020, 22:57:07 ÖS »
Playstation Classic bildiğim kadarıyla en dandik/zayıf classic/mini sistem... Mister için Playstation Core üzerinde 2 farklı kişi çalışıyor. Eğer başarırlarsa, Mister (DE10Nano) alırsın.
Mesaj Sayısı: 6.625
love is better than
« Yanıtla #4 : Ağustos 05, 2020, 23:35:35 ÖS »
Tamam abi. Teşekkürler.
deksar
Mesaj Sayısı: 284
« Yanıtla #5 : Ağustos 06, 2020, 16:45:37 ÖS »
Bilgi için teşekkürler, PS-IO'ya çok iyi alternatif.
HkRecai
Mesaj Sayısı: 724
« Yanıtla #6 : Ağustos 07, 2020, 20:57:19 ÖS »
XStation diye aratınca başka bir ürün çıkıyor.
Birinci ürün bir Terminal
İkinci ürün bir mod çalışması, Xbox ve Playstation kardeşliğine XStation demiş.
https://youtu.be/ngQPbk4H9Dw
XStation çok sevilen bir isim olmuş.
