commodore.gen.trCommodoreCommodore DonanımCommodore 64 Adı sanı belirsiz kartuş
Sayfa: [1] 2 3   Aşağı git
Gönderen Konu: Commodore 64 Adı sanı belirsiz kartuş  (Okunma Sayısı 30573 defa)
spunky
Mesaj Sayısı: 772
« : Temmuz 07, 2016, 19:33:38 ÖS »
Selamlar; Bugün benim deponun dehlizlerinde Serkan'la gezerken bir kartuş bulduk Üzerinde bir etiket yok, çalışıyor ama ne olduğu belli değil...
İçi böyle
Takınca da böyle diyor..
Ne ki bu ?
Hadi bu sefer kendin pişir kendin ye yaptırmayın bana
Amstrad CPC6128 |3.5" Hack|
Sensation
Mesaj Sayısı: 2.557
Killer Instinct
« Yanıtla #1 : Temmuz 07, 2016, 20:23:08 ÖS »
Kıyamet yaklaşıyor... Kahkaha
« Yanıtla #2 : Temmuz 07, 2016, 20:24:34 ÖS »
https://en.wikipedia.org/wiki/Vizastar
"Vizastar was the first integrated software package for the Commodore 64 home computer.[1] At the time of its introduction it was the only package for the C64 with features comparable to Lotus 1-2-3, including spreadsheet, database and graphics components. It had the ability to split or merge files between the database and spreadsheet components and could split the screen into up to 9 windows.[2]
To alleviate the C64's somewhat limited memory capacity when running complex software, Vizastar included a ROM cartridge that provided an additional 4K RAM and also served as a form of copy protection.[1] This allowed the program to remain compatible with third-party floppy disk drives for the C64, such as the Indus GT and MSD Super Disk, unlike many copy protected packages. Commodore serial printers were supported, as were RS-232 and Centronics printers with the appropriate interface.
The spreadsheet had a maximum size of 1000 rows by 64 columns, or 64,000 cells, but because only about 10k of memory was left available after the program was loaded, not all the cells could be used. The additional cells provided flexibility in the dimensions of the spreadsheet. The spreadsheet module had a macro feature that could execute a series of commands at once.
The database had a capacity of 1200 fields, which could each hold 124 characters. In order to keep down the programs memory requirements, it was necessary to export a database to the spreadsheet module in order to sort it.
It was later ported to the Commodore 128[3]"
« Yanıtla #3 : Temmuz 07, 2016, 20:26:46 ÖS »
https://en.m.wikipedia.org/wiki/Vizastar
Bununla alakalı herhalde. Gerçi burada bahsedilen ram'in bu kartuş üstünde olma ihtimali zayıf.
spunky
Mesaj Sayısı: 772
« Yanıtla #4 : Temmuz 07, 2016, 20:54:02 ÖS »
Galiba değil, programı indirip diskete attım, C64 açılışta 8'i kontrol ediyor ve aynı ekran geliyor. Bir de kartuşun üstünde Wiza yazıyor ama program Viza... Çakması falan olabilir belki ama yemedi şimdilik ..
« Yanıtla #5 : Temmuz 07, 2016, 22:07:09 ÖS »
ROM dump edilip içinde ipucu aranabilir.
« Yanıtla #6 : Temmuz 07, 2016, 22:13:46 ÖS »
vizastar'ın c128 versiyonunda kartuşta  ram yokmuş sadece rom varmış anladığım kadarıyla, muhtemelen c128 uyumlu bir kartuş
spunky
Mesaj Sayısı: 772
« Yanıtla #7 : Temmuz 07, 2016, 23:57:19 ÖS »
128'e takar deneriz bizde Kahkaha
NoStres
Mesaj Sayısı: 633
« Yanıtla #8 : Temmuz 08, 2016, 02:27:05 ÖÖ »
Veri korumak için; disket güvenlik anahtarı olabilir.
« Yanıtla #9 : Temmuz 08, 2016, 11:45:38 ÖÖ »
cp/m sistem disketini takıp commodore 128 de diagnostic ve util menusüne ulaşacaksın bir nevi ms-dos şirinliği olacak c128 de
ilkerficicilar
Mesaj Sayısı: 1.122
« Yanıtla #10 : Temmuz 08, 2016, 12:50:26 ÖS »
Compute! Gazette, Aralık 1986 sayısı, sayfa 97-101 arasında ayrıntılı tanıtımı yer alıyor:
https://archive.org/stream/1986-12-computegazette/Compute_Gazette_Issue_42_1986_Dec#page/n97/mode/2up
Bu arada, kartuşu dump edip paylaşabilir miyiz? 8K'lık gibi duruyor, şu şekilde kaydedilebilir:
Bir monitor programı içinden:
.S"vizastar.prg",08,$8000,$a000
Olmadı BASIC içinden:
poke43,0:poke45,255:poke44,128:poke46,159:save"vizastar.prg",8,1
spunky
Mesaj Sayısı: 772
« Yanıtla #11 : Temmuz 08, 2016, 14:46:41 ÖS »
Kartuşu takınca ekrandaki görüntü geliyor Basic'e falan düşemiyorum. Bir yöntemi var mı ?
« Yanıtla #12 : Temmuz 08, 2016, 14:48:38 ÖS »
run/stop restore yemiyor mu?
spunky
Mesaj Sayısı: 772
« Yanıtla #13 : Temmuz 08, 2016, 15:02:05 ÖS »
Yemiyor
ilkerficicilar
Mesaj Sayısı: 1.122
« Yanıtla #14 : Temmuz 08, 2016, 15:13:00 ÖS »
C128'e takıp, açılışta STOP tuşunu basılı tutarak Monitor'e de mi geçemiyoruz?
Sayfa: [1] 2 3   Yukarı git
