commodore.gen.trAmigaAmiga DonanımAmiga 4000 sarı ekran problemi
Sayfa: 1 2 [3]   Aşağı git
Gönderen Konu: Amiga 4000 sarı ekran problemi  (Okunma Sayısı 19454 defa)
phantom
Mesaj Sayısı: 935
« Yanıtla #30 : Ekim 22, 2018, 16:16:31 ÖS »
Offf kötü olmuş ya
« Yanıtla #31 : Ekim 22, 2018, 17:09:31 ÖS »
bende sizlerle hata kodlarını ve ekran renk kodlarını paylaşayım gerekli olabilir umarım işinize yarar
Here is some error codes I found from the November 1993 edition of CU Amiga. Perhaps some might find them useful
GURU CODES
General error codes
01 - Not enough memory
02 - Couldn't make library
03 - Can't open library
04 - Can't open device
05 - Can't open resource
06 - I/O error
07 - No signal
08 - Bad parameters
09 - Close library failed: usually too many closes
0A - Close device failed: or a mismatched close
0B - Process creation failed
Specific Alert Codes
EXEC Library
0001 - 68000 exception vector checksum (obs)
0002 - Execbase checksum bad (obs)
0003 - Library checksum failure
0005 - Corrupt memory list detected in FreeMem
0006 - No memory for interrupt servers
0007 - InitStruct() of an APTR source (obs)
0008 - A semaphore is in an illegal state of Rem Semaphore()
0009 - Freeing memory that is already free
000A - Illegal 68K exception taken (obs)
000B - Attempt to reuse active OIRequest
000C - Sanity check on memory list failed during AvailMem (MEMF_LARGEST)
000D - IO attempted on close IORequest
000E - Stack appears to extend out of range
000F - Memory header not located. Usually an invalid address passed to FreeMem
0010 - An attempt was made to use the old message semaphores
00FF - A quick interrupt has happened to an uninitialised vector
CPU Exceptions
0002 - Bus Error
0003 - Addressing error
0004 - Illegal instruction
0005 - Divide by zero
0006 - CHK instruction
0007 - TRAPV instruction
0008 - Privilege violation
0009 - Trace
000A - OpCode 1010
000B - OpCode 1111
000E - Stack frame format error
0018 - Spurious interrupt error
0019 to 001F - AutoVector Level 1 to 7 int error
Intuition Library
0001 - Unknown gadget type
0002 - Create port, no memory
0003 - Item plane alloc, no memory
0004 - Sub alloc, no memory
0005 - Plane alloc, no memory
0006 - Item box top <RelZero
0007 - Open screen, no memory
0008 - Open screen, raster alloc, no memory
0009 - Open sys screen, unknown type
000A - Add SW gadgets, no memory
000B - Open window, no memory
000C - Bad Stare Return entering Intuition
000D - Bad message received by IDCMP
000E - Weird echo causing incomprehension
000F - Couldn't open the Console Device
0010 - Intuition skipped obtaining a sem
0011 - Intuition obtained a sem in bad order
Graphics Library
0000 - Graphics out of memory
0001 - MonitorSpec alloc, no memory
0006 - Long frame, no memory
0007 - Short frame, no memory
0009 - Text, no memory for TmpRas
000A - BitBitMap, no memory
000B - regions, memory not available
0030 - Make V Por, no memory
000C - (GFX New Error)
000D - (GFX Free Error)
1234 - Emergency memory not available
0401 - Unsupported font description used
Workbench
0001 - No fonts
0001 - WB Bad Startup Msg1
0002 - WB Bad Startup Msg2
0003 - WB Bad IO Msg
0004 - WB Init Potion Alloc Drawer
0005 - WB Create WB Menus Create Menus1
0006 - WB Create WB Menus Create Menus2
0007 - WB Layout WB Menus Layout Menus
0008 - WB Add Tool Menu Item
000A - WB InitTimer
000B - WB Init Layer Demon
000C - WB Init WB Gels
000D - WB Init Screen and Windows1
000E - WB Init Screen and Windows2
000F - WB Init Screen and Windows3
0010 - WBMAlloc
Layers Library
0000 - Layers out of memory
Expansion Library
0001 - Freed free memory
Trackdisk Device
0001 - Calibrate: seek error
0002 - Delay: error on timer wait
Disk Resource
0001 - Get unit: already has a disk
0002 - Interrupt: no active unit
RamLib Library
0001 - Overlays are illegal for library segments
Console Device
0001 - Console can't open initial window
Timer Device
0001 - Bad request
0002 - Power supply: no 50/60 Hz ticks
Bootstrap
0001 - Boot code returned an error
Dos Library
0001 - No memory at startup
0002 - EndTask didn't
0003 - Qpkt failure
0004 - Unexpected packet received
0005 - Freevec failed
0006 - Disk block sequence error
0007 - Bitmap corrupt
0008 - Key already free
0009 - Invalid checksum
000A - Disk error
000B - Key out of range
000C - Bad overlay
000D - Invalid init packet for CLI/SHELL
Alert Objects
8001 - ExecLib
8002 - GraphicsLib
8003 - LayersLib
8004 - Intuition
8005 - MathLib
8007 - DOSLib
8008 - RAMLib
8009 - IconLib
800A - ExpansionLib
800B - DiskfontLib
800C - UtilityLib
800D - KeyMapLib
8010 - AudioDev
8011 - ConsoleDev
8012 - GamePortDev
8013 - KeyboardDev
8014 - TrackDiskDev
8015 - TimerDev
8020 - CIARsrc
8021 - DiskRsrc
8022 - MiscRsrc
8030 - BootStrap
8031 - Workbench
8032 - Diskcopy
8033 - GadTools
8035 - Unknown
Keyboard Caps Lock light
1 Flash = ROM (internal to keyboard processor)
2 Flashes = RAM (internal to keyboard processor)
3 Flashes = watchdog timer (IC 741s 123 or associated circuitry)
4 Flashes = A shortcut exists between two row lines or one of the seven special keys (not implemented), thanks for that Juv!
No Flashes = Main PCB fault
Amiga 1200 & 4000 Screen Colours
Colour Black: Opening Screen Initial hardware configuration passed. Initial system software passed. Final initialisation test passed
Colour Red: ROM error, reseat or replace Kickstart ROMs
Colour Green: CHIP RAM error
Colour Blue: Custom Chip(s) error
Colour Yellow: 68000 detected error before software trapped it (software or hardware error)
AmigaDos Error Codes
Displayed in CLI or Shell
103 - No free store
105 - Task table full
114 - Bad temlate
115 - Bad number
116 - Required arg missing
117 - Key needs arg
118 - Too many args
119 - Unmatched quotes
120 - Line too long
121 - File no object
122 - Invalid resident library
201 - No default dir
202 - Object in use
203 - Object exists
204 - Dir not found
205 - Object not found
206 - Bad stream name
207 - Object too large
209 - Action not known
210 - Invalid component name
211 - Invalid lock
212 - Object wrong type
213 - Disk not validated
214 - Disk write protected
215 - Rename across devices
216 - Directory not empty
217 - Too many levels
218 - Device not mounted
219 - Seek error
220 - Comment too big
221 - Disk full
222 - Delete protected
223 - Write protected
224 - Read protected
225 - Not a DOS disk
226 - No disk
233 - Is soft linked
234 - Object linked
235 - Bad hunk
236 - Not implemented
240 - Record no locked
241 - Lock collision
242 - Lock timeout
243 - Unlock error
303 - Buffer overflow
304 - ***Break
305 - File not executable
Mesaj Sayısı: 5.194
« Yanıtla #32 : Ekim 22, 2018, 17:15:48 ÖS »
GURU CODES
Benim aldığım kod hiç bir zaman buradaki kodlarla uyuşmadı Çok baktım ama yararlanamadım
Bende sarı ekran var ama cpu'm 060
« Yanıtla #33 : Ekim 22, 2018, 17:17:16 ÖS »
ben bu kodları amibaydan aldım sizlerle paylaştım size yararlı olabilecgini düşünmüştüm
Mesaj Sayısı: 5.194
« Yanıtla #34 : Ekim 22, 2018, 17:20:50 ÖS »
Kötü bir şey demedim hocam İyi yapmışsın Ben de daha önce bir çok kez faydalanmak istedim ama hiç işime yaramadılar diyerek şahsi tecrübelerimi paylaşmak istedim.
« Yanıtla #35 : Ekim 22, 2018, 18:53:32 ÖS »
Oğuzhan, kötü ihtimal anakartın üzerindeki çiplerin komple yanması...
(sallıyorum tabi ki )
Mesaj Sayısı: 5.194
« Yanıtla #36 : Ekim 23, 2018, 08:58:59 ÖÖ »
Ağzından bal damlıyor Artık üzüntüden ölmeyeyim diye seninkini yollarsın bana
Sayfa: 1 2 [3]   Yukarı git
