Gönderen Konu: zxspectrum için 4116-2N entegre  (Okunma Sayısı 7015 defa)
« : Mayıs 11, 2012, 12:09:57 ÖS »
elimde 4116-2N entegreleri gidik 4 tane spectrum48K var,bu entegreleri bulmak haliyle çok zor,bunların yerine alternatif olarak ne kullanılabilir? veya bu entegreleri nereden bulabilirim.  varmı önerisi olan?
Mesaj Sayısı: 3.441
« Yanıtla #1 : Mayıs 11, 2012, 21:10:15 ÖS »
http://www.zxshed.co.uk/sinclairfaq/index.php5?title=Replacement_Components
Integrated Circuits
RAM
MM5920N (national Semiconductors) chips are equivalent to 4116 RAM chips AM9016EDC (AMD) chips are the same as 4116 chips. IMS2600P-12 (Inmos) chips work in any upper RAM position (IC15-22) 41256 chips work in place of 4164 upper RAM chips V53C256P80L chips work in any upper RAM position (IC15-22) MN41257-12 chips work in any upper RAM position (IC15-22)
Burada da ilgili şeyler var...
http://www.electronicspoint.com/datasheet-4116-memory-chips-searching-sinclair-zx-spectrum-parts-t65261.html
I used to replace 4116 with 6164, ofcourse after disconnecting extra
power lines and fixing them to appropriate spot, like GND. Not really
high on aestetics and authenticity points, but it worked...
Burdada NTE2117 var buda üreticinin sayfasında 4116 nın muadili olarak belirtiliyor. Burdaki listeden muadil olan diğerleri görülüyor.
http://shop.vetcosurplus.com/catalog/product_info.php?manufacturers_id=14&products_id=2798
This part is the equivalent replacement for the following:
100017-001, 100017-001(ATARI), 1818-0340, 1818-1396, 1818-1467, 2117(RAM), 221-364, 2690(RAM), 3108003, 3108009, 4116, 4116(DRAM), 4116(RAM), 443-904, 4716(RAM), 5290(RAM), 5340-09488-00, 733W01513, 8041016, 8041016A, 8116(RAM), AM9016C, AM9016CDC, AM9016CPC, AM9016D, AM9016DDC, AM9016DPC, AM9016E, AM9016ECP, AM9016EDC, AM9016EPC, AXX3021, AXX3055, C014331, C014331-09, C2117-3, C2117-4, C2117-5, CO14331-09, D416C, D416C(RAM), D416(RAM), ECG2117, EF4116B, EF4116B-20, EF4116B-25, EF4116B-30, EF4116BP, F16K3, F16K3D, F16K3DC, F16K3P, F16K3PC, F16K4, F16K4D, F16K4DC, F16K4P, F16K4PC, F16K5, F16K5D, F16K5DC, F16K5P, F16K5PC, HM4716, HM4716-3, HM4716-4, HM4716P, HM4716P-3, HM4716P-4, HYB4116-3, HYB4116-4, HYB4116-5, IM4116-3, IM4116-3CDE, IM4116-3CJE, IM4116-3CPE, IM4116-4, IM4116-4CDE, IM4116-4CJE, IM4116-4CPE, ITT4116-3, ITT4116-4, ITT4116D-3, ITT4116D-4, ITT4116N-3, ITT4116N-4, MB8116E, MB8116EC, MB8116EP, MCM4116A-20, MCM4116A-25, MCM4116A-30, MCM4116AC-20, MCM4116AC-25, MCM4116AC-30, MCM4116AL-20, MCM4116AL-25, MCM4116AL-30, MCM4116B, MCM4116BP20, MCM4116BP25, MCM4116BP30, MCM4116BP35, MK4116-3, MK4116-4, MK4116J-3, MK4116J-4, MK4116J-44GP, MK4116J-53GP, MK4116N-3, MK4116N-3GP, MK4116N-4, MK4116N-44GP, MM5290, MM5290-3, MM5290-4, MM5290J-3, MM5290J-4, MM5290N-3, MM5290N-4, MN4116, MN4116P, N2690-3, N2690-4, N2690F-3, N2690F-4, N2690N-3, N2690N-4, NTE2117, P2117-3, P2117-4, P2117-5, P2217-3, P2217-5, SCM90072C, SCM90072L, SCM90072P, SK9832, SK9832/2117, TMM416D-3, TMM416D-4, TMM416DC, TMM416DC-3, TMM416DC-4, TMM416DP, TMM416DP-3, TMM416DP-4, TMM416P-3, TMM416P-4, TMS4116, TMS4116-20, TMS4116-25, TMS4116JL-20, TMS4116JL-25, TMS4116NL-20, TMS4116NL-25, UPD4116, UPD416, UPD416-1, UPD416-2, UPD416C, UPD416C-1, UPD416C-2, UPD416D, UPD416D-2, X400104162, Y130201002, ZP2117K, ZP2117Y
« Son Düzenleme: Mayıs 11, 2012, 21:21:54 ÖS Gönderen: commander64 » Logged
Mesaj Sayısı: 3.441
« Yanıtla #2 : Mayıs 11, 2012, 23:12:26 ÖS »
listedekilerden biri mm5290 aşağıdaki sitede var gözüküyor
http://www.ozkulelektronik.com/?p=mod.urunler&gr=33&page_id=23
« Yanıtla #3 : Mayıs 13, 2012, 13:14:10 ÖS »
@commander64 çok teşekkürler mm5290 sorun çıkartmaz inşallah
