commodore.gen.trAmigaAmiga Yazılımamigada müzik sevenlere
Gönderen Konu: amigada müzik sevenlere  (Okunma Sayısı 2636 defa)
EMREZ
Mesaj Sayısı: 1.938
« : Ekim 31, 2015, 22:08:02 ÖS »
bir a600 ile güzel iş çıkartılmış, ek bir cihaz bağlamadan da müzik yapabilirsiniz. yakında uygulamanın pdf kullanım klavuzu yapılacakmış.
http://pt1210.kikencorp.com/
The PT-1210 MK1 v1.0
The ProTracker Turntable
Credits
Original Concept - Hoffman & Akira
Code - Hoffman
Graphics - Akira
System Kill Code - Stingray
Testing - Akira & Tecon
Jungle DnB tune pack - Syphus
Bug reports to: pt1210@kikencorp.com
Facebook: https://www.facebook.com/PT1210
Date: EASTER 2014!!
** RELEASE NOTES **
Hi all, weclome to the first release of PT-1210 from Revision 2014. We have a
couple of tune packs for you, simply CD into the folder and run PT1210 to start
playing.
** WHAT IS IT **
PT-1210 is a program for DJ'ing ProTracker modules. It essentially turns
your Amiga into a turntable / CDJ with nudge, pitch control and so on.
It has a number of features but the most important one is that it can
re-pitch the samples played to match the BPM you want to play the tune at.
This means drum and music loops will still be in sync and the other
instruments will still be in key.
** WHAT DO I NEED **
It will run on pretty much any 68k Amiga, OSC/ESC, AGA, accelerated and so on.
I would recommend however that you run it using a CF card on the IDE port
with 2 meg of chip RAM. If you are using two Amigas I would also recommend
that they are the same type, like two A1200s or two A600s.
« Son Düzenleme: Ekim 31, 2015, 22:10:25 ÖS Gönderen: EMREZ » Logged
this is amiga speaking.
