commodore.gen.trAmigaAmiga GenelAmiga 600 1MB 3.9 Custom Rom Hazırlama Üzerine Beyin Cimnastiği
Sayfa: [1] 2 3 ... 9   Aşağı git
Gönderen Konu: Amiga 600 1MB 3.9 Custom Rom Hazırlama Üzerine Beyin Cimnastiği  (Okunma Sayısı 75564 defa)
toddler
Mesaj Sayısı: 1.396
« : Eylül 01, 2017, 23:02:15 ÖS »
Kısa bir süre önce A600 satın aldım. Amigastore.eu'dan aldığım Furia kart yolda. A600'de OS3.9 kullanacağımdan biraz ön hazırlık yapmak istedim.
Aşağıdaki başlığı takip etmişseniz yapılanlar yaklaşık olarak aynı.
http://www.commodore.gen.tr/forum/index.php?topic=14536.msg178777#msg178777
; Generated by Remus 1.51
;Options
SaveROM "Ram Disk:a60039normal.rom"
ModDir Modules/Others/
ROMBase $F80000
ROMSize 512
ImageType 0
Checksum
SpeedROM
;Build list
ADD Modules/44.57_ROMUpdate(3.9bb2)/exec_45.20(A1200-A500)2017
ADD Modules/BlizKick/NewAlert
ADD Modules/BlizKick/AlertFix
ADD Modules/40.63(A500-2000)/audio.device_37.10
ADD Modules/40.63(A500-2000)/battclock.resource_39.3
ADD Modules/40.63(A500-2000)/battmem.resource_39.2
ADD Modules/40.63(A500-2000)/card.resource_40.4
ADD Modules/40.63(A500-2000)/carddisk.resource_40.1
ADD Modules/40.63(A500-2000)/cia.resource_39.1
ADD Modules/40.63(A500-2000)/con-handler_40.2
ADD Modules/40.63(A500-2000)/disk.resource_37.2
ADD Modules/40.63(A500-2000)/dos.library_40.3
ADD Modules/40.63(A500-2000)/expansion_40.2(A500-600-2000)
ADD Modules/40.63(A500-2000)/gadtools.library_40.4
ADD Modules/40.63(A500-2000)/graphics.lib_40.24(OCS-ECS)
ADD Modules/40.63(A500-2000)/intuition.library_40.85
ADD Modules/BlizKick/PowerWindows_BKPatch
ADD Modules/40.63(A500-2000)/keymap.library_40.4
ADD Modules/40.63(A500-2000)/layers.library_40.1
ADD Modules/40.63(A500-2000)/mathffp.library_40.1
ADD Modules/40.63(A500-2000)/mathieeesingbas.lib_40.4
ADD Modules/40.63(A500-2000)/misc.resource_37.1
ADD Modules/40.63(A500-2000)/potgo.resource_37.4
ADD Modules/40.63(A500-2000)/ramdrive_39.35
ADD Modules/40.63(A500-2000)/ramlib_40.2
ADD Modules/40.63(A500-2000)/timer.device_39.4
ADD Modules/40.63(A500-2000)/utility.library_40.1(68000)
ADD Modules/40.63(A500-2000)/wbtask_39.1
ADD Modules/44.57_ROMUpdate(3.9bb2)/bootmenu_44.7(68020)
ADD Modules/44.57_ROMUpdate(3.9bb2)/console.device_44.8
ADD Modules/44.57_ROMUpdate(3.9bb2)/filesystem.resource_45.10
ADD Modules/Others/FastFileSystem_45.16
ADD Modules/44.57_ROMUpdate(3.9bb2)/ram-handler_44.24_NoBss
ADD Modules/Others/Shell-Seg
ADD "Modules/Peter Keunecke/icon.library.46.4.454"
ADD Modules/romboot/romboot44_3
ADD Modules/ResetCard/DosResetCard
ADD Modules/ResetCard/ColdResetCard
ADD Modules/LargeHD/128GB_Support/SCSI_v43_47_Cosmos/scsi.device_A600_A1200_43.46
ADD Modules/40.63(A500-2000)/trackdisk.device_40.1
ADD Modules/BlizKick/NoClick
ADD Modules/40.63(A500-2000)/input_40.1
ADD "Modules/Don Adan/wbfind"
A500-600-2000 40.63 3.1 rom ile BoingBag2 birleştirildi ve bir kaç ekleme-düzenleme yapıldı.
- Daha önceki rom başlıklarında icon.library ile ilgili bir problem görülmediği söylendiğinden güncel versiyonu kullanmayı tercih ettim.
- Cosmos'un NoClick'li trackdisk.device modülü ile disket drive sesi devam ettiği için BlizKick NoClick modülünü kullandım. Artık sadece ilk boot esnasında floppy click sesi geliyor. Boot ettikten sonra tık tık sesi duymayacaksınız.
- Cosmos'un scsi.device'ını (v43.46) kullandım.
- 3.1 rom'dan aldığım romboot40.1'i 44.3'e patch yaparak kullandım. Boot ekranında 3d Boing Ball göreceksiniz.
- NewAlert ve AlertFix yamaları yapıldı.
- intuition.library'ye PowerWindows_BKPatch'i yapıldı.
- A600'lerin PCMCIA portundaki reset sorununu ROM'dan çözmek için DosResetCard ve ColdResetCard yamaları yapıldı. (A1200'deki sorunun A600'de de olduğunu varsaydım.)
- FFS 45.13'den 45.16'ya güncellendi.
- Shell 45.7'den 45.38'e güncellendi.
- Tarih 2017 olarak güncellendi.
- Workbench.library romdan çıkarılarak wbfind roma eklendi. Workbench.library Library çekmecesinde bulunmalıdır.
Bu romu kullanabilmek için Devs: çekmecesindeki AmigaOS ROM Update'in adını değiştirmeli ya da başka bir çekmeceye taşımalısınız.
startup-sequence dosyasındaki scsi.device ile ilgili satırlar başına ";" konularak iptal edilmelidir.
Üst taraflarada aşağıdaki satır ilave edilmelidir.
C:SetPatch NOROMUPDATE QUIET
A600'ünüzde Gayle-01 varsa Furiatune ile ide on kullanabilirsiniz. Bende Gayle-02 olduğundan test edilememiştir. Gayle-02'de ide on yapmayınız. Zaten güncel scsi.device ile ide on hızına yakın bir hıza ulaşılmıştır.
* Boot.PNG (12.34 KB, 649x507 - Görüntüleme: 2235 kez.)
* Boot2.PNG (10.56 KB, 726x594 - Görüntüleme: 1456 kez.)
* Workbench.PNG (21.46 KB, 642x516 - Görüntüleme: 2176 kez.)
« Son Düzenleme: Eylül 14, 2018, 22:31:22 ÖS Gönderen: toddler » Logged
C64|C|G|C128|1541U2
A500|A500+|Slim SDHxC|Gotek
Dingoo A320(OpenDingux)
Pandora(First Batch)
RaspberryPi 1-2-3
BananaPi/Pro
Mesaj Sayısı: 2.627
« Yanıtla #1 : Eylül 02, 2017, 00:11:09 ÖÖ »
A600 Furia'da OS3.9 kullanıyorum 16 renk, PAL:High Res Laced tercih ediyorum. Graphic Memory 1.680.500, Other memory 6.620.900 gibi değerlerde. Shadowrom aktif, IDESpeedUp ON, FPU ve Cache ON olarak kullanıyorum. Sistem açılışı gayet hızlı. 1MBlık Maprom için sıkıntı çıkmaz gibime geliyor. Amidock da çalışıyor elbet.
Abi bu remusu henüz indirdim inceleyemedim. Bu modülleri remus ile aynı çekmeceye mi yerleştireceğiz. Birde bu modülleri toplu nerede bulabiliriz?
toddler
Mesaj Sayısı: 1.396
« Yanıtla #2 : Eylül 02, 2017, 00:23:12 ÖÖ »
Modülleri istediğin çekmeceye koyabilirsin. 3.1 rom ve RomUpdate'i RomSplit ile modüllerine ayıracaksın. Diğer modüller için geliştiricileri takip etmek gerekiyor. Remus konusunda Mfilos'un blogunu incele. Adım adım anlatmış.
« Son Düzenleme: Eylül 02, 2017, 09:11:45 ÖÖ Gönderen: toddler » Logged
C64|C|G|C128|1541U2
RaspberryPi 1-2-3
BananaPi/Pro
toddler
Mesaj Sayısı: 1.396
« Yanıtla #3 : Eylül 03, 2017, 12:35:47 ÖS »
@emarti romu test etti. Maprom olarak çalışıyor.
Abi ide speedup ON konumunda iken herhangi bir drivedaki dosyaları açma sırasında pencere içi gösterimde donuyor.
Biraz araştırma yapınca şöyle birşey buldum.
IDE speed need Gayle-01 on board the A600 and scsi.device v44.1 or v46.1
when using Gayle-02 must be "ide off" !!!
Romdaki Doodbrey'in scsi.device'ını Don Adan'ın scsi.device'ı (v46.0) ile değiştirdim. Benim Furia kart yolda olduğundan test etmesi için @emarti'ye yeni versiyonu gönderdim.
« Son Düzenleme: Eylül 03, 2017, 13:12:37 ÖS Gönderen: toddler » Logged
C64|C|G|C128|1541U2
RaspberryPi 1-2-3
BananaPi/Pro
« Yanıtla #4 : Eylül 03, 2017, 14:22:11 ÖS »
Bandeki gayle chip i bu sanırım v1 olandan. Böyle olmasına rağmek ide on olunca bahsi geçen sapıtmalar oluyor.
scsi.device  40.05
* gayle.png (111.47 KB, 253x277 - Görüntüleme: 1396 kez.)
« Son Düzenleme: Eylül 03, 2017, 14:44:38 ÖS Gönderen: Kaan Akkurt » Logged
toddler
Mesaj Sayısı: 1.396
« Yanıtla #5 : Eylül 03, 2017, 22:15:38 ÖS »
A600'ü hiç incelememiştim fakat öğreneceğimiz çok şey varmış. Board revizyonlarına baktım ve şöyle birşey gördüm.
Motherboard revisions
revision 1, 1.1
labeled as A300
Gayle 01
Kickstart v37.299 or v37.300
revision 1.3
labeled as A600
revision 1.5
Kickstart v37.300 or v37.350
revision 2B, 2D
Kickstart v37.350
Gayle 02
İlk revizyonlarda görüldüğü gibi A300 adını vermişler ve boardlar hazırlanmış fakat son aşamada A600 olmasına karar verip kasaya A600 ismini basmışlar sanırım. İlk revizyonlarda Gayle-01 kullanıldığı yazılmış ama gördüğüm fotoğraflarda rev1'lerin bazısında Gayle-01 bazısında Gayle-02 vardı. Bazı turbo kartların bazı Gayle revizyonlarında problem çıkardığından bahsedilmiş. Mesela ACA620 için Gayle-02 olmalıymış. Sanırım Jens daha sonra ACA620'de sorunu halletmiş.
Boboo_SK Furia kartı elinde bulunan board revizyonlarıyla test yapmış ve sonuçlar şöyle;
A300 REV 1.0 Gayle-02 - Working
A600 REV 1.5 Gayle-01 (GAL-fix) - Working
A600 REV 2.0 Gayle-02 - Working
PPA.PL'de ise board revizyonu ve kickstart versiyonunuz önemsizdir denmiş. IDE performans artışı için 2gb yada 4gb hızlı cf kartlar kullanılması ve kickstart'ın fastram'e taşınarak shadowrom işlevinin kullanılması gerektiği anlatılıyor.
ide on kulllanmak için A600'de Gayle-01 mi yoksa Gayle-02'mi var ona bakmak gerekiyor. Gayle-01'deki bir bug sebebiyle ide aygıtını %30 (4.3MB/s) daha hızlı çalıştırmak mümkünmüş. Fakat Gayle-02'de bu bug giderildiği için %3-5 hızlanma sağlanabiliyor ve stabil olmuyor.
@Kaan Akkurt senin Gayle-02 olduğu için zaten %3-5 artış için ide on yapmana gerek yok. Kickstart'ı maprom olarak kullan, shadowrom aktif olsun. Ayrıca partisyonlarını da SFS ya da PFS yaparsan zaten o hız artışını sağlamış olacaksın. Tabii bunları yaparken birde en iyi performansı alabileceğimiz scsi.device versiyonunu bulmamız gerekiyor.
« Son Düzenleme: Eylül 03, 2017, 22:22:54 ÖS Gönderen: toddler » Logged
C64|C|G|C128|1541U2
RaspberryPi 1-2-3
BananaPi/Pro
« Yanıtla #6 : Eylül 03, 2017, 22:49:44 ÖS »
Ya şu yaptıklarınızın hiç birini yapmıyorum.
Os 3.1 veya 3.9 u yüklüyorum
Ne scsi.device ne maprom hiç bir şey yapmıyorum..
Ben de bir gariplik mi var ?
Söylediğiniz ve konuştuğunuz şeyler genelde bana karışık geliyor..
Her amiga için her turbo için farklı farklı işlemler yapmak
benim kafamı çok karıştırır.
« Yanıtla #7 : Eylül 03, 2017, 23:21:55 ÖS »
Bütün bu zamazingoları yapınca , (sadece rom değil, .device lardan da bahsediyorum)
Toplam performans artışı sizce % kaç?
toddler
Mesaj Sayısı: 1.396
« Yanıtla #8 : Eylül 03, 2017, 23:48:04 ÖS »
Furia kartım İspanya'dan Türkiye'ye gönderilmiş görünüyor. Deneyip göreceğiz artık. Belkide bu kadar uğraşmaya değmeyecek ama daha hızlı çalışabileceğini bilerek yaşayamam Kahkaha
C64|C|G|C128|1541U2
RaspberryPi 1-2-3
BananaPi/Pro
Mesaj Sayısı: 2.627
« Yanıtla #9 : Eylül 04, 2017, 10:47:20 ÖÖ »
@Toddler abi scsi.device 46 için gönderdiğin son rom denemelerinde ide on durumunda bazı programların açılışlarında (iGame, Whdload olarak direkt Agony oyunu açımı, eagle player vb. hatalar aldım. Boot sonrası WB Screen ekranı karşılaması sırasında donma olabiliyor. Enteresan her zaman yapmayabiliyor. Ama stabl değil.
Yalnız ide off maprom aktif iken herşey normal gibi. Ama OS'un ilk açılış ve Workbench ekranına düşüp amidock çıkışını beklemeden kickstart versiyonu için sağ click ve about'a gelemeden bazen kitleniyor. Amidock ekrana düşüp bakınca sorun yok.
A600 için verdiğin bilgiler için teşekkürler
Furia kartına bir an önce kavuşman dileği ile. Adı üstünde seni kızdırmadan olmaz bu iş. Ben en çok kartı boarda takma sırasında sinir olmuştum.
Mesaj Sayısı: 2.627
« Yanıtla #10 : Eylül 04, 2017, 10:51:55 ÖÖ »
Ya bir de HDDsiz açılış ekranında 3D boing görmek için harddisk takılı iken early startup içinden harddiskleri disabled yapmama rağmen hDDsiz açılış ekranına düşemiyorum. MAPROM aktifken bunu yapmanın bir yolunu bulamadım. Mümkün mü?
« Yanıtla #11 : Eylül 04, 2017, 12:10:21 ÖS »
Şu en son
scsi.device
ve diğer device ları
klasörlerdeki upgrade edileek diğer dosyları toplu olarak zip lesiniz
atsanız da
tüm os lara kopyalasak.
nasılsa hepsi için geçerli değil mi ?
Mesaj Sayısı: 2.627
« Yanıtla #12 : Eylül 04, 2017, 13:11:42 ÖS »
Şu en son
scsi.device
atsanız da
Gökçe o vakit zevki kalmıyor; plajdaki her kum tanesini tek tek kovaya koymak gibi düşün.
Startup-sequence için bunlarla uğraşmayalım diye rom içine atip deneme yapmaliyiz. Gerçi bizim yaptığımız maprom olarak. Bu şekilde boot süresi de kısalıyor.
« Yanıtla #13 : Eylül 04, 2017, 13:24:04 ÖS »
Bir çok library, ve device var ..
fat 95
pcmcia compactflash device lar.
vs
vs
bunlar tüm işletim sistemleri için sabit değil mi ?
en üst versiyonunu kullanmak işi hızlandırıyor..
bunları neden bir noktada toplamıyoruz.
istediğimiz workbenchi sıfırdan yükledikten sonra
son versiyonlarla dolu klasörü üstüne kopyalarız olay biter
Mesaj Sayısı: 2.627
« Yanıtla #14 : Eylül 04, 2017, 13:49:36 ÖS »
Ama bazılari için kopyala yapıştır haricinde load module ve setpatch işlemleri yapmamız gerekebilir. Aslında sıkıntı burada basliyor.
Sayfa: [1] 2 3 ... 9   Yukarı git
