commodore.gen.trAmigaAmiga DonanımAmiga 600 için yeni ram kartı A6095
Gönderen Konu: Amiga 600 için yeni ram kartı A6095  (Okunma Sayısı 3255 defa)
« : Aralık 12, 2017, 09:14:23 ÖÖ »
A6095 9.5MB EXTRA FAST RAM MEMORY EXPANSION CARD FOR AMIGA 600
€ 89.99
Brand new, great quality A6095 9.5MB Extra Fast Memory Expansion Card for Amiga 600.
This amazing brand new card will give you an extra 9.5 MB FAST RAM on your Amiga 600.
Plug and Play card, you dont need any driver or anything else. You can use even with disabled startup-sequence. All you have to do is just put the card on Motorola MC 68000 processor on Amiga 600 motherboard (you can still use trapdoor expansion for extra 1 MB CHIP RAM). You dont need any soldering or tools. Simply put on processor within seconds. PLCC socket mounted on card is extremely strong and solid. You can even lift up and hold motherboard together with bottom case when the card is installed just holding the card! (see photo for proof).
Jumper settings:
ON/OFF - you can enable or disable the card
RST/CFG - when you hold 3 buttons reset keys from keyboard for about 5-6 seconds you can switch from 5.5 MB (PCMCIA friendly) to 9.5 MB (PCMCIA not friendly) and opposite.
9.5/5.5 - permanently settings (5.5 MB PCMCIA friendly or 9.5 MB PCMCIA not friendly)
SLOW ONLY - will give you 1.5 MB extra slow memory only (required for some A500 games).
Free shipping worldwide for this item (simply choose during checkout "shipping to Ireland" and it will be posted for free to any country worldwide.
https://sordan.ie/product/563/a6095-95mb-extra-fast-memory-expansion-card-for-amiga-600/
Def Leppard
Mesaj Sayısı: 1.379
« Yanıtla #1 : Aralık 12, 2017, 13:59:07 ÖS »
Furia bu tür amiga 600 ram kartlara göre az daha pahalı ve sonuçta turbo kartı. ram kartların daha uygun olması lazım. ebayda buna benzer yine amiga 600 için ram kartları görmüştüm. Tabi amiga ya bir şeyler üreten insanları da her zaman takdir etmek lazım  Karizmatik
« Son Düzenleme: Aralık 12, 2017, 14:01:36 ÖS Gönderen: Def Leppard » Logged
Amiga Repair Service
« Yanıtla #2 : Aralık 12, 2017, 14:54:08 ÖS »
@Def Leppard
Ortalama yıllık gelirimiz 40.000 euro olsa hiç tereddüt etmezdik muhtemelen. Fakirleştiğimizin farkında değiliz...
