Gönderen Konu: S-Video Adaptor  (Okunma Sayısı 10145 defa)
« : Haziran 27, 2018, 09:59:50 ÖÖ »
Belki bizden de yapanlar çıkar Kahkaha
S-Video Adaptor (only for Tbtorro's / Jozsef Vamosi's video upgrade kit)
8 £
Edit: Price is £8 per kit plus postage, which is £1.50 for the UK and £3 for Europe unregistered.
Following on from my earlier posts, I have a limited number of these S-Video adaptors available in kit form. They're designed to fit in the space left by removing the RF modulator from Amiga 600s and 1200s, and they allow S-Video connection to the upgraded video encoder. Please be aware that they will *not* work with the original video encoder - more elaborate circuits are required for that. This adaptor is intended only for use with the CXA1645 video encoder chip!
Fine soldering will be required, but if you've fitted the encoder upgrade kit, this won't be any problem. Three connections are needed as shown in the photo - Chroma to pin 15 of the encoder, Luma to pin 16, and Ground to any ground point (a handy one is the 4th pin of the PAL modulator connection, as shown in the photo). Unfortunately there's nowhere else to obtain the Chroma and Luma signals other than directly from the chip pins.
The kit contains the PCB, two capacitors, two SMT resistors, the socket, and the wires, screws and spacers needed to fit it. Note that the S-Video connector is a tight fit for the modulator opening in the new Kickstarter A1200 cases, but it does fit with a little persuasion (as seen in the photos). The original case's RF modulator opening has more clearance and so is an easier fit.
It's only a very simple board, but of course, I can't guarantee it will work with your setup or won't damage your Amiga. Use it at your own risk.
I'm asking for £8 per kit plus postage, which is £1.50 for the UK and £3 for Europe unregistered. Registered / tracked shipping is available for additional cost.
Thanks!
https://www.facebook.com/groups/CommodoreAmiga/permalink/10155689549819157/?sale_post_id=10155689549819157
https://www.ebay.com/itm/Sony-CXA1645P-CXA1645-RGB-Video-Encoder-IC-DIP24-x-2pcs-/151400904577
* 36200060_10160680713180077_8351135385299976192_n.jpg (19.67 KB, 461x260 - Görüntüleme: 1289 kez.)
* 36223201_10160680717830077_6504671456612319232_o.jpg (38.34 KB, 720x405 - Görüntüleme: 1346 kez.)
* 36303919_10160680718935077_6933604948496089088_o.jpg (79 KB, 720x405 - Görüntüleme: 1405 kez.)
* 36225014_10160680754010077_4353671377153163264_o.jpg (44.91 KB, 720x405 - Görüntüleme: 1342 kez.)
* 36223894_10160680718155077_105780139647827968_o.jpg (38.58 KB, 720x405 - Görüntüleme: 1353 kez.)
« Son Düzenleme: Haziran 27, 2018, 10:02:05 ÖÖ Gönderen: Kaan Akkurt » Logged
Mesaj Sayısı: 1.619
« Yanıtla #1 : Haziran 27, 2018, 11:28:52 ÖÖ »
Amiga 600'ümü kontrol edeyim. Çip uygunsa bunu uygularım. Zamanla S-Video saplantısı edindim Kahkaha Kahkaha Kahkaha
Aykiri1
Mesaj Sayısı: 1.135
« Yanıtla #2 : Haziran 27, 2018, 12:17:04 ÖS »
Cxa olan makinede zatwn rgb var
Svideo gereksiz
« Yanıtla #3 : Haziran 27, 2018, 16:46:16 ÖS »
Paylaşım için teşekkürler Kaan abi
Mesaj Sayısı: 1.619
« Yanıtla #4 : Haziran 27, 2018, 17:25:35 ÖS »
Svideo gereksiz
Gereksiz demeyelim. Yalnızca S-Video girişi olan cihazları kullanmayı tercih eden insanlar olabilir.
Aykiri1
Mesaj Sayısı: 1.135
« Yanıtla #5 : Haziran 27, 2018, 18:20:35 ÖS »
İhtiyaçlara göre kıyaslama yaparsak tercihler ihtiyaç ve imkanlara göre değişir..
Rgb varken svideo
Svideo varken composite
Composite varken RF
Gereksizdir.
HkRecai
Mesaj Sayısı: 925
« Yanıtla #6 : Haziran 27, 2018, 20:56:32 ÖS »
Evdeki PS2'de Hdmi adaptör, component, rgb, composite, vga ve S-Video ile görüntü alabiliyorum, S-video tercih ediyorum, görüntü bana daha güzel geliyor, ayrıca rgb kablo ile bağlayınca sanırım bazı oyunların ntsc olmasından üstten alttan 2 parmak siyah şerit çekiyor, S-video ile full ekran 4/3 oluyor. PS2'de kişisel tercihim S-Video.
Mesaj Sayısı: 1.619
« Yanıtla #7 : Haziran 27, 2018, 23:24:33 ÖS »
Rgb varken svideo
Composite varken RF
Gereksizdir.
Yorum yok. Polemiğe girmeyeceğim.
« Yanıtla #8 : Haziran 28, 2018, 07:36:47 ÖÖ »
Rgb varken svideo
Composite varken RF
Gereksizdir.
Bence bu bile yeterli polemik için
Mesaj Sayısı: 2.394
« Yanıtla #9 : Haziran 28, 2018, 11:01:59 ÖÖ »
Daha iyi sinyal girişi daha iyi çıkış kalitesi anlamına gelmeyebiliyor. Üreticiler beklenmedik şeyler yapmış olabiliyor.
keremimo
Mesaj Sayısı: 57
« Yanıtla #10 : Haziran 28, 2018, 13:25:57 ÖS »
Bunların tek işlevi SCART girişli televizyonlara sahip olmayan Amerikanların az buçuk iyi bir görüntü kalitesi edinmesini sağlamak değil mi? Türkiye'de aşırı gereksiz.
Mesaj Sayısı: 1.619
« Yanıtla #11 : Haziran 29, 2018, 09:17:45 ÖÖ »
Değil.
S-Video SCART için bir alternatif olarak tasarlanmamıştır.
Öyle olsaydı bazı video sistemlerinde hem SCART hem de S-Video olmazdı.
Bazı video kaynakları ve göstericileri yalnızca S-Video çıkışı/girişi sunar. (Bkz. bazı PVM modelleri, dijital kameralar, güvenlik cihazları vs.).
Dolayısıyla paylaşılan S-Video modları da buna hizmet eder. Örneğin elimdeki 3 cihazda (VCD player, PVM, Sony PS1) S-Video çıkışı/girişi var bu cihazları SCART/RGB ile kullanmak imkansızdır/imkansıza yakındır.
Benzer şekilde Amiga 600/CD32 RGB çıkış verse de elinizde S-Video girişi kabul eden çok kaliteli bir CRT varsa RGB kullanacağım demezsiniz.
keremimo
Mesaj Sayısı: 57
« Yanıtla #12 : Temmuz 02, 2018, 09:24:47 ÖÖ »
Değil.
Hocam dediğinizde doğruluk payı var da kendi adıma konuşayım RGB olmayan bir ekranı en başta almam, yaptığım yayınlar gereği her şeyin RGB olması çok sağlıklı sonuçlar veriyor
