commodore.gen.trAmigaAmiga DonanımCF2IDEPLUS FOR AMIGA A600 A1200 ADAPTER
Gönderen Konu: CF2IDEPLUS FOR AMIGA A600 A1200 ADAPTER  (Okunma Sayısı 4798 defa)
« : Kasım 02, 2018, 08:46:03 ÖÖ »
CF Angle adapter + 40 PIN IDE Connector for additional 3.5" devices: hard drives or CD-ROM drives.
This adapter allows you to use CF card + any other 3.5" 40 PIN IDE device. You will be able to boot from CF card and it also converts the 2.5" 44 PIN IDE into 3.5" 40 PIN IDE.
Master/Slave jumper available.
The adapter is designed to take as little space as possible and use more extensions in your Amiga 600/1200.
It fits A600 and A1200 motherboard perfectly. It is to be mounted on the top left hand side of your desktop so it does not interfere with any other device inside.
There is no need to connect additional power or any hard drive tape cable to use CF card, simply put the adapter inside your Amiga motherboard with the Compact Flash Card and format it. For all 3.5" devices connected to 40 PIN IDE connector you need additional source of power.
£19.99 GBP
https://retroready.one/products/brand-new-cf2ideplus-for-amiga-a600-a1200-adapter-no-ide-cable-second-ide-40pin-port?fbclid=IwAR2dTJE1qC3ZtL7ftOfNaxxUL4ROHgeW4mQnhRqmuOvarVGSaD_pkGyhpBw
Mesaj Sayısı: 1.740
İlla ki Amiga
« Yanıtla #1 : Kasım 02, 2018, 08:50:19 ÖÖ »
Üçlü 44pin IDE kablo 2 adet CF adapter Ali amcadan daha ucuza gelir.
Amiga 1200 + Vampire V1200
LG 24MA53 TVMonitör
Amiga 2000
2 Casper M989A Monitor
Commodore64
« Yanıtla #2 : Kasım 02, 2018, 08:54:01 ÖÖ »
Ali amca
 Kahkaha Kahkaha
Jax
Mesaj Sayısı: 878
« Yanıtla #3 : Kasım 06, 2018, 08:21:13 ÖÖ »
Furia lı Amiga 600 e uygun olur mu?
« Yanıtla #4 : Kasım 06, 2018, 08:26:52 ÖÖ »
uyar sanırım.
Bende şundan var. birbirilerine çok benziyorlar
Jax
Mesaj Sayısı: 878
« Yanıtla #5 : Kasım 06, 2018, 09:33:08 ÖÖ »
Tam aradığım gibi.
