Gönderen Konu: floppy emulatoru snes ile çalıştırdım  (Okunma Sayısı 20629 defa)
Arda
Mesaj Sayısı: 2.326
I'm *the* guy from Argleton
« Yanıtla #15 : Kasım 20, 2008, 21:56:08 ÖS »
ozkano, you should write a batchfile to do this process automagically
Does floppy->MFM converter utility has command line switches or gui only?
« Yanıtla #16 : Kasım 20, 2008, 22:15:16 ÖS »
arda öğrencilerinede böylemi ders veriyon
Arda
Mesaj Sayısı: 2.326
« Yanıtla #17 : Kasım 20, 2008, 22:17:06 ÖS »
aşağı-yukarı..
Jeff_HxC2001
Mesaj Sayısı: 16
« Yanıtla #18 : Kasım 20, 2008, 22:47:43 ÖS »
the step 2 & 3 are useless : the software create the floppy image directly from the rom file.
there are a command line version of the hxc floppy emulator software to convert a large quantities of floppy image with one command line ;-) (this soft are called "img2hfe").
« Son Düzenleme: Kasım 20, 2008, 22:50:31 ÖS Gönderen: Jeff_HxC2001 » Logged
« Yanıtla #19 : Kasım 20, 2008, 23:13:04 ÖS »
your software does not work with the hardware emrez did it is almost identical yours, most of the part is taken from your project
I'll try to make your project, your software is better atleast supports more device
Jeff_HxC2001
Mesaj Sayısı: 16
« Yanıtla #20 : Kasım 21, 2008, 01:31:55 ÖÖ »
i think that the PIC firmwares are very close (emrez used it as a start point), so it should support hfe file without problem.
« Yanıtla #21 : Kasım 21, 2008, 08:47:43 ÖÖ »
jeff, is it possible to make similar project like cd-rom emulator
the point is old video game consoles have laser problems, (by the way they have specific protocols not regular IDE port) same as floppy emulator, a cdrom emulator, so just putting iso to sd and play
« Yanıtla #22 : Kasım 25, 2008, 23:49:07 ÖS »
<a href="http://vimeo.com/moogaloop.swf?clip_id=2344633&amp;server=vimeo.com&amp;fullscreen=1&amp;show_title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=01AAEA" target="_blank">http://vimeo.com/moogaloop.swf?clip_id=2344633&amp;server=vimeo.com&amp;fullscreen=1&amp;show_title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=01AAEA</a>
ahan işte video
tabu
Mesaj Sayısı: 1.005
« Yanıtla #23 : Kasım 26, 2008, 08:42:07 ÖÖ »
Grafikleri güzelmiş be bu cihazın, boktan bişi sanıyodum ben
« Yanıtla #24 : Kasım 26, 2008, 09:30:46 ÖÖ »
yapma şimdi, bazı özellikler amiga da yok, sprite rotate zoom in out, gerçekten başarılı bir makina
Mesaj Sayısı: 11.418
« Yanıtla #25 : Kasım 26, 2008, 09:43:26 ÖÖ »
SNES'i görmeden önce bende aynı şekilde düşünürdüm...Ama çok güzel oyunları, grafik ve ses var... Şu GameDoctor'dan bir tane edinmek lazım...
Arda
Mesaj Sayısı: 2.326
« Yanıtla #26 : Kasım 27, 2008, 14:34:34 ÖS »
snes sevdiğim konsollardandır. "Chrono Cross" başka türlü nasıl insanlığa kazandırılacaktı?
Eskiden GP32'yi portable snes olarak kullanıyordum neredeyse Kahkaha
Özkan, floppy emulatörü herhangi bir modifikasyon yapmadan direk takarak kullandın değil mi?
Ayrıca bir floppy'e sığmayan snes oyunu var mı?
« Son Düzenleme: Kasım 27, 2008, 14:46:03 ÖS Gönderen: Ref » Logged
« Yanıtla #27 : Kasım 27, 2008, 15:27:51 ÖS »
ufak bi mıdifikasyon yapıyon, çunku snes gamedoctor pc floppysi kullanıyor
snes in rom adresleme kapasitesi 64 mbit yani 8 mbyte dır, ama bugune kadar 64 mbit oyun çıkmadı en buyuk kapasite 32 mbit, 32 mbit oyunları bu cihaz da 8 mbit ler halinde blocklar var yani dosyayı 4 bölup hepsini teker teker upload ediyon
