Gönderen Konu: HXC Floppy Emulator  (Okunma Sayısı 47233 defa)
tolga abaci
Mesaj Sayısı: 641
« Yanıtla #60 : Ağustos 17, 2010, 09:05:55 ÖÖ »
Congratulations Jeff, that is good news indeed... I am glad that the emergence of UFE has motivated you to come up with a creative solution for the Amiga write issue. As they say, necessity is the mother of invention...
That said, I guess you are only able to buffer a couple of tracks in that small 32KB RAM chip... Have you tested to see if you are able to support all situations where writes are involved?
-Tolga
EMREZ
Mesaj Sayısı: 1.938
« Yanıtla #61 : Ağustos 17, 2010, 11:04:28 ÖÖ »
Hi Jeff,
I got the new emulator and it works really well. I wonder when SDcard HxCFloopy Emulator Manager will be ready for Amiga.I guess there is no driver sound as amiga writes back but if there is any other way for pic18 solution that would be great.I care more of that amiga writes back.I suggest the new emulator to everyone.I had some problems on the firmware.I think new firmware is out and I will try it soon.However I do work with pic32 and I believe that it is enough on its own, it is a expensive solution.PCB is needed even to test it.
Regards,
this is amiga speaking.
EMREZ
Mesaj Sayısı: 1.938
« Yanıtla #62 : Ağustos 22, 2010, 18:20:09 ÖS »
Beklediğim firmware bugün çıktı, birde amiga loader çıkarsa mükemmel olur. bazı modifiyeler gerekiyor, umarım bendeki rev.B dir. formda bakşa hangi arkadaşlarda var? uzun süredir upgrade yapmamıştım, amiga 1200 de çok iyi olacak diye düşünüyorum. mk4 pcida sorunsuz kurdum a1200 de 30 gb harddisk taktım süper bir sistem oldu. 50 mhz fpu +32 mb ram kick 3.1
http://hxc2001.free.fr/floppy_drive_emulator/sd_hxc_floppy_emulator_firmware_release_notes.txt
Firmware SD HxCFloppyEmulator v1.3.0.0
EMREZ
Mesaj Sayısı: 1.938
« Yanıtla #63 : Ağustos 28, 2010, 09:44:04 ÖÖ »
23K256 yı ekledim baştan geri yazma olmadı, galiba hatalı yükleme yaptım derken yeni bir firmaware yüklemem gerektiğini okudum, ve sonuç mükemmel.Videoları yakında eklerim.. Tebrikler Jeff.
* untitled.JPG (116.53 KB, 1136x840 - Görüntüleme: 1946 kez.)
* Modify.JPG (40.07 KB, 663x424 - Görüntüleme: 1857 kez.)
« Son Düzenleme: Ağustos 28, 2010, 16:16:12 ÖS Gönderen: EMREZ » Logged
« Yanıtla #64 : Ağustos 28, 2010, 09:58:01 ÖÖ »
@emre 23K256 nerden ve kaça aldın
EMREZ
Mesaj Sayısı: 1.938
« Yanıtla #65 : Ağustos 28, 2010, 10:19:59 ÖÖ »
20 uero kargo ücreti ile İngiltere'den getirttim Özkan. başka lazım olan şeylerde aldım.
