commodore.gen.trAmigaAmiga GenelMorphos OWB versiyon 1.11
Gönderen Konu: Morphos OWB versiyon 1.11  (Okunma Sayısı 5646 defa)
Blasterreal
Mesaj Sayısı: 862
« : Kasım 07, 2010, 17:34:29 ÖS »
Origin Web Browser'ın yeni versiyonu çıkmış. Eklenen ve düzeltilenlerin listesi aşagıdadır.
http://fabportnawak.free.fr/owb/owb-morphos-1.11.lha indirme bağnatısı burda
 05.11.2010: OWB 1.11
  - Updated to WebKit to r71312 (5th November 2010). Fixes amongst other things:
    - lazy loading of thumbnails on youtube and google image.
    - crash at http://www.reco.se.
  - Updated to Pixman 0.20.0.
  - Now compiled with GCC 4.4.4.
  - Avoid redrawing a bitmap each time a data chunk is received from network. Should speed
    up pictures loading time, or at least decrease CPU usage substancially.
  - Added a workaround to avoid using "complex font rendering" code path (triggered by
    "text-rendering: optimizedlegibility" CSS attribute, or by fonts requiring ligatures).
    The complex mode is indeed not implemented in cairo/freetype font backend, which
    caused the sites using it to show invisible text (for instance http://www.mentor.com/).
  - Replaced the contextmenu for media elements with WebKit's own implementation.
  - Added SELECTEDTEXT REXX command (text is converted to local charset).
  - Added "Ignore" to the available mimetype user actions.
  - Added Safari 5 and Opera 10 user agents.
  - Updated youtube_fullscreen_fix.js to support embedded youtube as well (remove/readd the script to take
    the new URL pattern into account)
  - In youtube.js, remove explicitely the dynamically created video element at unload event,
    to avoid a potential media instance "leak".
  - Hopefully fixed some rare random crash related to a bug in reference pointers holding cairo objects.
  - Enabled again the "death requester" in case of low memory, since it had been disabled somehow.
    This requester is somewhat useful, because it frees allocated memory and kills OWB in a harmless way.
Amiga 1200
Amiga OS 3.9
Morphos 3.9
toddler
Mesaj Sayısı: 1.396
« Yanıtla #1 : Kasım 07, 2010, 20:05:49 ÖS »
OWB çevirisi ne alemde bu arada
C64|C|G|C128|1541U2
A500|A500+|Slim SDHxC|Gotek
Dingoo A320(OpenDingux)
Pandora(First Batch)
RaspberryPi 1-2-3
BananaPi/Pro
« Yanıtla #2 : Kasım 07, 2010, 20:11:58 ÖS »
Origyn Web Browser
Yanlış okumuşum. (ne alemdeyi ne olarak algılamışım)
Blasterreal
Mesaj Sayısı: 862
« Yanıtla #3 : Kasım 07, 2010, 20:26:54 ÖS »
owb morphos repolarında yok malesef ona ayrı baş vurmak gerekiyor. şu an morphosu tamamlamaya devam ediyoruz. owb 1.10 ait catalog dosyası owb 1.11'e uymadı saçma sapan ibareler cıktı 1.11 için. Sanırım her seferinde bir düzenleme yapmak gerek. owb sonraki adım benim için
Amiga 1200
Amiga OS 3.9
Morphos 3.9
toddler
Mesaj Sayısı: 1.396
« Yanıtla #4 : Kasım 07, 2010, 20:31:50 ÖS »
Daha önce OWB çevirisi yaptığını söylediğin için sormuştum aslında. MorphOS çevirisi daha önemli. Her türlü çeviri testi itinayla yapılır Kahkaha
C64|C|G|C128|1541U2
RaspberryPi 1-2-3
BananaPi/Pro
