Sayfa: [1] 2 3   Aşağı git
Gönderen Konu: 2. Amiga zorro projesi  (Okunma Sayısı 22234 defa)
« : Eylül 23, 2014, 22:34:54 ÖS »
ilki thylacine usb controllerdı, bunu başarı ile yaptıktan sonra sırada picasso ii ekran kartının klonu var, bugun dosyaları yolladım ve ödemeyi yaptımi, boardların gelmesini bekliyorum
http://retrocu.blogspot.com.tr/2014/09/second-amiga-zorro-card-project.html
this is my second attempt on  building professional pcb from china, design of the card belongs to matzo from a1.org (http://www.a1k.org/forum/showthread.php?t=40955) and based on Georg Braun (http://www.gb97816.homepage.t-online.de) picasso ii zorro card for GBA 1000
lets give few information about the board
pcb is 4 layer, so production is a little bit pricy
board is very compact, small can works A500 as well tower Amiga'a A2000,A3000 and A4000
board has breakable part as seen picture, if you want to use on zorro port you have to use as is, if you want to use with A500 you have to remove left edge and solder cpu slot for A500 cpu port
Orginal picasso is full length graphic card, came with 2 MB ram on it, it has pass through port allows to transmit Amiga's 15Khz video to output port, unfortunately it does not scan doubler video so you can not get Amiga's native video from picasso unless you have multi sync monitor
orginal picasso has 5 Pal chips which make communication between Cirus Logic chip Amiga zorro port, in this version instead of 5 Pal chips Braun use 1 Xilinx Cpld,
« Son Düzenleme: Eylül 23, 2014, 22:40:38 ÖS Gönderen: ozkano » Logged
« Yanıtla #1 : Eylül 24, 2014, 02:20:46 ÖÖ »
Özkan yine iş başında.
ancalimon
Mesaj Sayısı: 921
« Yanıtla #2 : Eylül 24, 2014, 06:13:27 ÖÖ »
Özkan anlamıyorum. Zamanım yok diyosun, oturmuş Zorro ekran kartı imalatına girmişsin.
« Yanıtla #3 : Eylül 24, 2014, 06:16:19 ÖÖ »
24 saat çalışıyorum
usagi
Mesaj Sayısı: 41
« Yanıtla #4 : Eylül 24, 2014, 07:38:06 ÖÖ »
Sayın @ozkano'dan clone-a-dore'un (http://clone-a-dore.blogspot.com.tr) Amiga versiyonunu bekliyoruz.
A500+ A501 (1536 KiB Chip)/LG HDReady 24"/Altec Lansing 2+1 -> Demo Machine
"Amiga" değil."COMMODORE Amiga"
« Yanıtla #5 : Eylül 24, 2014, 09:49:57 ÖÖ »
Clone-a-Dore da nereden çıktı? Commodore 64 klonu üreten üretene. Ama ben pek beğenmedim, en azından Mini-ITX yapsaymış Micro-ATX nedir yahu? Kahkaha
« Yanıtla #6 : Eylül 24, 2014, 10:28:59 ÖÖ »
benimde hep aklımda bu tarz proje var zaman ve $$$ lazım
atlantis
Mesaj Sayısı: 2.118
« Yanıtla #7 : Eylül 24, 2014, 11:06:17 ÖÖ »
Ben zaten bu kadar zamanı ve parayı nasıl buluyorsun merak ediyorum. Ufacık parça alırken elli kere düşünüyoruz biz Kahkaha
Truva Linux
http://www.truvalinux.org.tr
http://retromiga.blogspot.com
https://www.bananapi.gen.tr
« Yanıtla #8 : Eylül 24, 2014, 11:53:10 ÖÖ »
hobi + zevk meselesi insan sevdiği bir şeye zaman ve para rahatlıkla bulabilir mesele bu kadar basit bence.
« Yanıtla #9 : Eylül 24, 2014, 11:54:47 ÖÖ »
bu arada yeni kartın hayırlı olsun özkan
atlantis
Mesaj Sayısı: 2.118
« Yanıtla #10 : Eylül 24, 2014, 12:37:15 ÖS »
gelir durumu önemli değil ayni Kahkaha
Truva Linux
« Yanıtla #11 : Eylül 24, 2014, 13:49:37 ÖS »
bence önemli değil keza çevremde bakıyorum bazı insanların evi yok kirada oturuyor maaşı belli vs ama altındaki araba son model veya iyi bir araba burdanda şu anlaşılıyor sevince para ve zaman önemli değil benzer çuvalla örnek verilebilir.
« Son Düzenleme: Eylül 24, 2014, 13:52:37 ÖS Gönderen: ibo1973 » Logged
« Yanıtla #12 : Eylül 24, 2014, 18:11:26 ÖS »
saol ibrahim abi, hani senin orda çipini değiştirdiğimiz kart var ya onun pcb sini yaptırıyorum bakalım çalıştırabilecekmiyim
« Yanıtla #13 : Eylül 25, 2014, 13:43:43 ÖS »
Çalışır inşallah
« Yanıtla #14 : Ekim 24, 2014, 13:08:14 ÖS »
bugun pcb ler geldi, yanzlız ufak bir yeri eksik yapmışlar, sadece kasalı amigalarda çalışacak, A500 dede çalışması için adaptör yapmam gerek
http://retrocu.blogspot.com.tr/2014/10/new-picassso-2-pcbs-arrived.html
Sayfa: [1] 2 3   Yukarı git
