commodore.gen.trGenel KategoriGenel SohbetAmiga 1200 1MB Custom Rom Hazırlama Üzerine Beyin Cimnastiği
Sayfa: [1] 2 3 ... 8   Aşağı git
Gönderen Konu: Amiga 1200 1MB Custom Rom Hazırlama Üzerine Beyin Cimnastiği  (Okunma Sayısı 64935 defa)
toddler
Mesaj Sayısı: 1.396
« : Temmuz 13, 2017, 14:37:05 ÖS »
Mfilos ve Plazma dergisinin rom hazırlama sayfalarını okudum. İçeriği aşağıda bulunan 1mb rom hazırladım.
http://www.mfilos.com/2010/12/guide-create-and-burn-custom-kickstart.html
http://www.plazma-dergi.org/dergi/04/chunk/ch21.html
; Generated by Remus 1.0 rc35
;Options
SaveROM Ram Disk:normal.rom
ModDir Modules/Others/
ROMBase $F80000
ROMSize 512
ImageType 1
Checksum
SpeedROM
;Build list
ADD Modules/44.57_ROMUpdate(3.9bb2)/exec_45.20(A1200-A500)
ADD Modules/BlizKick/NewAlert
ADD Modules/BlizKick/AlertFix
ADD Others/Blizkick/1MB_ROM
ADD Modules/40.68(A1200)/audio.device_37.10
ADD Modules/40.68(A1200)/battclock.resource_39.3
ADD Modules/Don Adan/battmem.resource
ADD Modules/44.57_ROMUpdate(3.9bb2)/bootmenu_44.7(68020)
ADD Modules/40.68(A1200)/card.resource_40.4
ADD Modules/40.68(A1200)/carddisk.resource_40.1
ADD Modules/Don Adan/cia.resource
ADD Modules/40.68(A1200)/con-handler_40.2
ADD Modules/Others/console.device_44.10
ADD Modules/Don Adan/disk.resource
ADD Modules/Others/dos.library_42.1
ADD Modules/40.68(A1200)/expansion_40.2(A1200)
ADD Modules/44.57_ROMUpdate(3.9bb2)/filesystem.resource_45.10
ADD Modules/44.57_ROMUpdate(3.9bb2)/filesystem_45.13
ADD Modules/40.68(A1200)/gadtools.library_40.4
ADD Modules/40.68(A1200)/input_40.1
ADD Modules/40.68(A1200)/keymap.library_40.4
ADD Modules/Thomas Richter/layers.library_45.27
ADD Modules/Don Adan/mathffp.library
ADD Modules/Don Adan/mathieeesingbas.library
ADD Modules/Don Adan/misc.resource
ADD Modules/Don Adan/potgo.resource
ADD Modules/44.57_ROMUpdate(3.9bb2)/ram-handler_44.24_NoBss
ADD Modules/40.68(A1200)/ramdrive_39.35
ADD Modules/Don Adan/ramlib
ADD Modules/Others/romboot_44.3
ADD Modules/40.68(A1200)/timer.device_39.4
ADD Modules/CosmosDevice/trackdisk.device_40.2
ADD Modules/Don Adan/utility.library
ADD Modules/40.68(A1200)/wbtask_39.1
ADD Modules/Peter Keunecke/icon.library.46.4.454
ADD Modules/40.68(A1200)/graphics.lib_40.24(AGA)
ADD Modules/CosmosLibs/intuition.library_40.86.b14-72
ADD Modules/BlizKick/PowerWindows_BKPatch
ADD Modules/ResetCard/DosResetCard
ADD Modules/ResetCard/ColdResetCard
ADD Modules/LargeHD/128GB_Support/SCSI_v43_45_ChrisToni/A1200IDE.scsi.device.43.45
ADD Modules/Others/fat95
;Options
SaveROM Ram Disk:extended.rom
ROMBase $E00000
ROMSize 512
ImageType 1
Checksum
SpeedROM
;Build list
ADD Modules/Others/romheader_45.21
ADD Modules/Others/workbench.library_45.136
ADD Modules/44.57_ROMUpdate(3.9bb2)/shell_45.7
ADD Modules/Others/compactflash.device
ADD Modules/Others/pfs3_aio-handler
ADD Modules/Others/SmartFilesystem
Remus ile Amiga 1200 için 1mb rom oluşturmak için normal rom ve extended rom ayrı ayrı oluşturuluyor.
Byte swap olarak oluşturduğumuz normal ve extended rom dosyalarını 27c400'lere öylece yazamıyoruz. Winhex ile normal rom dosyasını normal1 ve normal2, extended rom dosyasını extended1 ve extended2 olarak ikişer parçaya bölüyoruz.
Sonra tekrar birleştirmek gerekiyor. Kahkaha extended1 ve normal1 dosyalarını U6A.rom olarak birleştiriyoruz. extended2 ve normal2 dosyalarını U6B.rom olarak birleştiriyoruz. Neden böyle derseniz Amiga önce extended romu okuyormuş. Neyse bölüp birleştirdiysek yazmaya hazır hale gelmiş demektir.
Yapılan birkaç önemli değişiklik şu şekilde;
- Exec BoingBag2 versiyonu kullanıldı.
- Graphics.library Kickstart 3.1 rom versiyonu kullanıldı.
- Scsi.device büyük partisyonları destekliyor. Ben 32gb cf kartımı 2gb+30gb şeklinde kullanıyorum.
- layery.library hızlanma sağladığından junk görüntü glitch'i gözardı edilerek roma eklendi.
- Güncel icon.library kullanıldı.
- intuition.library'ye PowerWindows_BKPatch'i yapıldı.
- A1200'lerin PCMCIA portundaki reset sorununu ROM'dan çözmek için DosResetCard ve ColdResetCard yamaları yapıldı.
- Cosmos'un trackdisk.device'ı (v40.2) kullanıldı. 40.1'den tek farkı versiyonu ve NoClick uygulanmış olması.
- NewAlert ve AlertFix yamaları eklendi.
- Fat95, Compactflash.device, Pfs, Sfs eklendi.
Amiga şu haliyle çok hızlı boot ediyor ve romupdate resetleri tarih oldu.
Bu rom kullanılıyorsa Devs: çekmecesindeki AmigaOS ROM Update dosyalarının ismi değiştirilmeli yada başka bir çekmeceye taşınmalı.
Startup-Sequence dosyasında LoadModule ve LoadResident ile yüklediğiniz library vs. varsa hepsinin başına ";" koyup devre dışı bırakın.
Scsi.device ile ilgili satırların başına da ";" koyun. Rom içeriğinde 128gb destekleyen Scsi.device mevcut.
SetPatch ile başlayan satırların başına ";" koyarak devre dışı bırakın ve aşağıdaki satırı üstlerde bir yere yazın.
C:SetPatch NOROMUPDATE QUIET
* Boot.PNG (40.65 KB, 727x597 - Görüntüleme: 1273 kez.)
* P_20170716_001257_p.jpg (670.45 KB, 3072x4096 - Görüntüleme: 1239 kez.)
« Son Düzenleme: Temmuz 16, 2017, 00:11:42 ÖÖ Gönderen: toddler » Logged
C64|C|G|C128|1541U2
A500|A500+|Slim SDHxC|Gotek
Dingoo A320(OpenDingux)
Pandora(First Batch)
RaspberryPi 1-2-3
BananaPi/Pro
« Yanıtla #1 : Temmuz 13, 2017, 15:31:08 ÖS »
Öncelikle çok güzel haber..
Defflepardddddddddddddd duy sesimiz
Bu romun içeriği neler?
Yani normal 3.1 romdan farklı olarak
standart bileşenler mi koydun..
blizzkick falan ile uğraşma bence
standart herkesin sorunsunz kullanabileceği ama herkesin 3.9 workbenchini hızlandıracağı bir rom olsun
toddler
Mesaj Sayısı: 1.396
« Yanıtla #2 : Temmuz 13, 2017, 15:41:09 ÖS »
Eğer çalışırsa içinde 3.1 rom dosyaları, boingbag güncellemeleri ve diğer library güncellemeleri olacak. Blizzkick vs. olmayacak. Rom içeriğinde görünen 1MB_ROM modülü 1mb rom hazırlamak için gerekli.
« Son Düzenleme: Temmuz 13, 2017, 17:01:06 ÖS Gönderen: toddler » Logged
C64|C|G|C128|1541U2
RaspberryPi 1-2-3
BananaPi/Pro
« Yanıtla #3 : Temmuz 13, 2017, 16:34:52 ÖS »
Eline sağlık, güzel faydalı bir çalışma olmuş...
Def Leppard
Mesaj Sayısı: 1.379
« Yanıtla #4 : Temmuz 13, 2017, 16:37:33 ÖS »
Bende deneyebilirim güzel çalışma umarım çalışır tebrikler
Geçende bu konu aklıma gelmişti neden 512kb a sığdırmak için dosya eksiltiyoruz zaten 27c400 ler 512x2 1mb hatta 27c800 ile 1+1 2mb yerde olabilir. bu konuyu Alpyre soracaktım tam da isabet oldu. Hatta hiç eksiltmeden updateler eklenerek bir rom hazırlanabilirmi ? diye soracaktım...
« Son Düzenleme: Temmuz 13, 2017, 16:51:36 ÖS Gönderen: defleppard » Logged
Amiga Repair Service
« Yanıtla #5 : Temmuz 13, 2017, 17:32:49 ÖS »
Tam deflepparda boş rom gönderdiğim dönemde çok güzel haber..
Amiga 600 içinde 1200 içinde süper olacak...
Nitekim kaç tane kaldı sende boş hatırlayamadım
« Yanıtla #6 : Temmuz 13, 2017, 17:38:18 ÖS »
Bir de copyright zaten yalan olmuş.
orayada commodore.gen.tr yazalım..
tam hedef olalım
Mesaj Sayısı: 2.633
« Yanıtla #7 : Temmuz 13, 2017, 18:06:01 ÖS »
Hele şükür diyebilecek miyiz?
Def Leppard
Mesaj Sayısı: 1.379
« Yanıtla #8 : Temmuz 13, 2017, 19:55:02 ÖS »
Telif hakları Toddler de ona göre  Karizmatik
toddler
Mesaj Sayısı: 1.396
« Yanıtla #9 : Temmuz 13, 2017, 20:05:32 ÖS »
Ben romlara Gökçe ve defleppard yazıp downloada açıcam Kahkaha
Şaka bir yana adamın biri ebay üzerinden Hyperion rom satıyor. Hyperion ayakta uyuyor sanırım.
C64|C|G|C128|1541U2
RaspberryPi 1-2-3
BananaPi/Pro
« Yanıtla #10 : Temmuz 13, 2017, 20:13:24 ÖS »
Ayakta bekliyoruz haberleri.
Defleppard eprom yaziciyi acti isitiyor
Yarin urunlerimi kargoluyor
Acaba romlari da yazip mi gonderecek?
Hersey toddlerdan gelecek habere bağlıydı
Tum amiga severler sinav sonucu bekler gibi bekliyordu
O kickstart görüntüsü artik Türkiyede de olacak miydı.....
toddler
Mesaj Sayısı: 1.396
« Yanıtla #11 : Temmuz 13, 2017, 20:28:06 ÖS »
Şöyle bir resim paylaşayım. Karizmatik Kullanılan ekipman TL866CS'den TL866A'ya dönüştürdüğüm programlayıcı ve Özay'ın 27C4096 adaptörüdür. Onlarında testi yapılmış oldu. TL866 ile 27C400 yazarken VPP Voltage'ı 12.50V olarak ayarlamak gerekiyor. En azından ben öyle yaptım.
« Son Düzenleme: Temmuz 13, 2017, 20:37:02 ÖS Gönderen: toddler » Logged
C64|C|G|C128|1541U2
RaspberryPi 1-2-3
BananaPi/Pro
« Yanıtla #12 : Temmuz 13, 2017, 21:11:18 ÖS »
Anaaaaaaaa
Mesaj Sayısı: 2.633
« Yanıtla #13 : Temmuz 13, 2017, 23:21:11 ÖS »
@toddler @defleppard'a mı gönderecek romu, @defleppard'dan mı tedarik edeceğiz? Biri bişey desin. Ekran görüntüleri ile ağzımız iyice sulandı
« Yanıtla #14 : Temmuz 13, 2017, 23:28:31 ÖS »
Çok güzel. Fakat gördüğüm kadarıyla Cosmos'un exec.library'sini kullanmışsın. Bazı programlarla sorun yarattığını hatırlatayım. MUI programlarında bazen Recoverable Alert'e neden olurken, SAS/C ile direkt guru meditation'a düşüyor.
1MB Rom çok faydalı olur. Ancak temel kütüphanelerde (özellikle exec ve graphics) BB2'den ileriye gitmenizi pek tavsiye etmiyorum (diğerlerinde yardırabilirsiniz ).
NOT: Blizkick yamalarından bazıları çok faydalı. Örneğin intuition.library'ye PowerWindows_BKPatch'i muhakkak yapın. A1200'lerin PCMCIA portundaki reset sorunu ROM'dan çözmek için DosResetCard ve ColdResetCard yamaları da es geçilmemeli. Sadece WinUAE'de (ve belki SCSI harddisk kullanan gerçek Amiga'larda) kullanılacak ROM'lara özel olarak scsi.library'ye NOIDE yaması yapılabilir. Bunların dışındakiler fanteziye girer.
Sayfa: [1] 2 3 ... 8   Yukarı git
