commodore.gen.trAmigaAmiga YazılımAmiga connected thru Composite to my Intensity Shuttle Issue
Gönderen Konu: Amiga connected thru Composite to my Intensity Shuttle Issue  (Okunma Sayısı 3092 defa)
JesseVoss
Yeni Üye
Mesaj Sayısı: 1
« : Mayıs 21, 2018, 17:55:39 ÖS »
Hello there
I bought this device to stream Amiga usage on my channel. Howevr, .. no matter what I do, I only get black screen.My Amiga 1200 got composite, so I have connected my composite cable to my A1200 and then to my Blackmagic Intensity Shuttle. Then I have connected HDMI cable to a screen, but nothing!?I use the usb3 version with latest osx and your software. The device see that there is a connection, but nothing gets thru when I choose PAL??? I can see on my monitor here that something is happening, but nothing gets thru? Is the AmigaOS screenmodes not seen by the Intensity Shuttle? Should I deliver it back or is there a solution for this?
Please help.
I didn't find the right solution from the Internet.
References:-
https://forum.blackmagicdesign.com/viewtopic.php?t=58418&p=335314
Explainer video production agency
Thanks
keremimo
Mesaj Sayısı: 57
« Yanıtla #1 : Mayıs 22, 2018, 02:27:04 ÖÖ »
Are you trying to passthrough a composite signal from the HDMI? That won't work.
Edit: Even if it did, your monitor probably cannot display 50hz images (Assuming you have a PAL Amiga)
« Son Düzenleme: Mayıs 22, 2018, 03:29:04 ÖÖ Gönderen: keremimo » Logged
