Sayfa: [1] 2 3 4   Aşağı git
Gönderen Konu: Greaseweazle  (Okunma Sayısı 20340 defa)
« : Ekim 19, 2019, 06:05:03 ÖÖ »
Greaseweazle v0.1 First Release!
Read/write any floppy disk from your host PC!
Windows, Mac, Linux supported
Beta software: Please report issues
https://github.com/keirf/Greaseweazle/releases/download/v0.1/Greaseweazle-v0.1.zip
To build and program Greaseweazle you will need the following parts:
STM32 "Blue Pill" board
USB-TTL serial adapter
Firmware programming file
Programming proceeds as for the FF OSD project but using the downloaded Greaseweazle HEX file.
The Greaseweazle control program requires Python v3 to be installed on your host PC.
Firmware Programming
https://github.com/keirf/Greaseweazle/wiki/Firmware-Programming
Hardware Connections
https://github.com/keirf/Greaseweazle/wiki/Hardware-Connections
Software Installation
https://github.com/keirf/Greaseweazle/wiki/Software-Installation
Software Usage
https://github.com/keirf/Greaseweazle/wiki/Software-Usage
Greaseweazle reads and writes SCP image files. These can be used or analysed in several ways:
WinUAE, FS-UAE (Universal Amiga Emulator): Directly support SCP files
What is a SCP file?
Secure copy protocol (SCP) is a means of securely transferring computer files between a local host and a remote host or between two remote hosts. ... "SCP" commonly refers to both the Secure Copy Protocol and the program itself.
« Son Düzenleme: Aralık 19, 2021, 21:14:28 ÖS Gönderen: Kaan Akkurt » Logged
« Yanıtla #1 : Ekim 19, 2019, 14:30:06 ÖS »
tam olarak ne işe yarar ?
Mesaj Sayısı: 5.198
« Yanıtla #2 : Temmuz 01, 2020, 10:15:08 ÖÖ »
A USB interface and tool for reading and writing floppy disks in any format: PC, Amiga, Amstrad, all kinds of synths, and many more!
demiş.
Meali;
Her formattaki disk için hem okuma hem yazma yaptırabilen (Pcnizde, standard bir disk sürücü kullanarak) USB arabirime sahip bir cihaz.
Kaan hocam herkesin ağzına balı çalıp kaçmışsın Az detay ver Proje ne durumdaymış. Sanırım bir ilerleme olmamış?
« Yanıtla #3 : Temmuz 01, 2020, 17:48:15 ÖS »
demiş.
Meali;
Aksine geliştirmeye devam ediyor..
https://github.com/keirf/Greaseweazle/wiki/Downloads
40 dakika önce yeni versiyon da çıkarmış v0.20
Bu projesi benim hiç bir işime yaramıyor. Forumda ihtiyaç duyacak birileri mutlaka vardır. Ama öyle ben taktım aa disketler kopyalanıyor nekadardakolaymış tarzı bir proje değil bu
« Yanıtla #4 : Temmuz 01, 2020, 18:09:10 ÖS »
Güzel projeye benziyor bu konudaki gelişmeleri bekliyorum
« Yanıtla #5 : Temmuz 01, 2020, 19:02:23 ÖS »
Custom floppy controller mi yazmışlar yani? Catweasel tarzı...
Mesaj Sayısı: 5.198
« Yanıtla #6 : Temmuz 01, 2020, 19:02:54 ÖS »
Catweasel’in acik kaynak kodlusu gibi
« Yanıtla #7 : Aralık 19, 2021, 21:13:26 ÖS »
v0.33
Support high-density Amiga images (1760kB ADF)
IPF: Automatic write verification
New format specifiers for Acorn DFS and ADFS
New image handlers for Acorn: ADS, ADM, ADL, SSD, DSD
« Yanıtla #8 : Temmuz 19, 2022, 09:32:10 ÖÖ »
Greaseweazle Tools 1.1
Release Notes:
New IMG formats: pc98.dd, pc98.hd
IBM FM, MFM: Fix bugs in raw track decoder
gw info: Report MCU information (type, speed, SRAM)
greaseweazle-1.1-win.zip
https://github.com/keirf/greaseweazle/releases/download/v1.1/greaseweazle-1.1-win.zip
greaseweazle-1.1.zip
https://github.com/keirf/greaseweazle/releases/download/v1.1/greaseweazle-1.1.zip
https://github.com/keirf/greaseweazle/wiki
« Yanıtla #9 : Temmuz 19, 2022, 09:40:10 ÖÖ »
@Kaan Akkurt
Yap şundan da şöyle janjanlı kasalı falan, alalım bundan, Özgür Dereli kombo da olabilir
« Yanıtla #10 : Temmuz 19, 2022, 09:47:26 ÖÖ »
Bunun için yapılmış kasa tasarımları var, pcbye uymazsa da uydururum ve üretmek isteyenlere baskı konusunda yardımcı olabilirim. Benim iş sezonum başlıyor, elimdeki iki proje dışında bunun üretimine giremeyeceğim.
@Kaan Akkurt
Mesaj Sayısı: 4.063
« Yanıtla #11 : Temmuz 19, 2022, 10:34:23 ÖÖ »
İlgilenenler için şöyle bir proje var.
https://www.pcbway.com/project/shareproject/Greaseweazle_F1_Floppy_Driver_Blue_Pill_MurTek_dafd93a4.html
« Son Düzenleme: Haziran 23, 2023, 23:56:59 ÖS Gönderen: fort_apocalypse » Logged
murtek
Mesaj Sayısı: 682
« Yanıtla #12 : Ağustos 15, 2022, 09:17:58 ÖÖ »
  Arkadaşlar Merhaba,
  Atari ST için disket yazmam gerekti. Windows xp yüklü bilgisayar, dahili disket sürücü  omniflop şu bu derken, Greaseweazle projesine denk geldim. Universal bir okuma/yazma projesi olması beni cezbetti. Bluepill alıp yükleme deneme yanılma GUI vs. derken çalıştırıp disketleri yazıp işimi bitirdim.
 En sevdiğim tarafı WinUAE içinde gerçek disketi takıp çalıştırmak oldu. Meşhur tık tık disket sürücünün disket bekleme sesini duyunca adeta mest oldum.
  Greaseweazle F1 modeli için kendi revize PCB mi yapıp derli toplu hale getirip kullanacağım.  Eğer talep eden arkadaşlar olur ise, proje satış başlığı açıp, disket sürücüsü vs. tüm ekipmanları ile tak kullan şeklinde satış da yapabilirim.
* gw1.jpg (126.22 KB, 828x478 - Görüntüleme: 348 kez.)
* gw2.jpg (139.78 KB, 828x465 - Görüntüleme: 375 kez.)
* gw3.jpg (960.69 KB, 1768x1512 - Görüntüleme: 400 kez.)
« Son Düzenleme: Ağustos 15, 2022, 09:23:02 ÖÖ Gönderen: murtek » Logged
« Yanıtla #13 : Ağustos 15, 2022, 09:37:38 ÖÖ »
Almayı düşünürüm.
« Yanıtla #14 : Ağustos 15, 2022, 10:15:12 ÖÖ »
Bende düşünebilirim .
Sayfa: [1] 2 3 4   Yukarı git
