commodore.gen.trAmigaAmiga YazılımAction's Guide to AGA-Fixing!
Gönderen Konu: Action's Guide to AGA-Fixing!  (Okunma Sayısı 3176 defa)
AmigaFUN
Mesaj Sayısı: 1.160
MC68060 inside!
« : Kasım 27, 2014, 23:14:53 ÖS »
Panoda bulunsun.
http://zakalwe.fi/~shd/amiga-cracking/agafix-v2.html
AmigaAmigaAmiga
« Yanıtla #1 : Kasım 28, 2014, 08:17:23 ÖÖ »
        move.l  d0,d1
        lsl.l   #2,d1
        lea     addresstable,a0
        move.l  (a0,d1.l),a1
        jsr     (a1)                ;Jump to fetched address
        move.w  #$95,d1
        moveq.l #0,d0
addresstable:
        dc.l    $00004000,$00004046,$0000502A,...
A very convenient technique, except if the programmer has the stupid idea to use the unused most significant byte of an address (for instance at location (addresstable)) to store 1 byte data, such as a counter. Then, the JSR will only be correct if the value is 0, else it will crash.
Jump tablosunun kullanılmayan bitini sayaç olarak kullanmak nasıl bir zihniyettir. Üniversitelerde spagetti koda örnek olarak gösterilebilir herhalde.
