commodore.gen.trAmigaAmiga DonanımFlashFloppy yeni gotek firmware
Sayfa: 1 2 3 [4] 5 6 ... 16   Aşağı git
Gönderen Konu: FlashFloppy yeni gotek firmware  (Okunma Sayısı 185520 defa)
« Yanıtla #45 : Ağustos 26, 2018, 12:11:10 ÖS »
v0.9.28a
New image types supported:
IMG: Fluke 9100 (host=fluke)
MBD: Spectrum MB02
LCD/OLED: Display folder names in brackets
https://github.com/keirf/FlashFloppy/releases/tag/v0.9.28a
Mesaj Sayısı: 5.194
« Yanıtla #46 : Eylül 17, 2018, 13:05:45 ÖS »
v0.9.29a
New and improved image handlers:
ST: Fix 80-cyl single-sided images
IMG: Kaypro (host=kaypro)
IMG: MSX fix 40-cyl/5.25" formats (host=msx)
IMG: PC-DOS fix missing IAM (host=pc-dos)
IMG: All: Support long sectors (>1024k)
Indexed mode: Don't require DSKA0000 image
https://github.com/keirf/FlashFloppy/releases/download/v0.9.29a/flashfloppy_v0.9.29a.zip
« Yanıtla #47 : Eylül 17, 2018, 13:11:09 ÖS »
v0.9.29a
Hemen güncelleyeyim Kahkaha
Mesaj Sayısı: 2.751
« Yanıtla #48 : Eylül 17, 2018, 13:29:28 ÖS »
Akşam Sound Canvas'takini güncelleyeyim ben de.
Mesaj Sayısı: 5.194
« Yanıtla #49 : Ekim 09, 2018, 16:40:42 ÖS »
v0.9.30a
Release Notes:
    TI99: Fix V9T9/DSK double-sided images
    HxC Compat: Enter slot-based mode even with no AUTOBOOT.HFE
    HFE: Support HFEv2 images
https://github.com/keirf/FlashFloppy/releases/tag/v0.9.30a
Mesaj Sayısı: 2.626
« Yanıtla #50 : Ekim 09, 2018, 17:12:30 ÖS »
Sabah akşam yeni sürüm, facebookteda rahat durmuyor, çalışkan adam
Mesaj Sayısı: 5.194
« Yanıtla #51 : Ekim 30, 2018, 18:23:42 ÖS »
v0.10
FF.CFG: Allow up/down inputs to be reversed
Reverse original two buttons (twobutton-action=reverse)
Reverse rotary encoder direction (rotary=reverse)
Modified version numbering scheme and remove alpha status
https://github.com/keirf/FlashFloppy/releases/download/v0.10/flashfloppy-v0.10.zip
Mesaj Sayısı: 5.194
« Yanıtla #52 : Kasım 01, 2018, 22:32:44 ÖS »
v0.11
Release Notes:
Detect and report upside-down data ribbon cable
FF.CFG: Configurable OLED brightness/contrast (oled-contrast=)
FF.CFG: Configurable head settle time (head-settle-ms=)
FF.CFG: Fix comma-separated-list parsing (eg. rotary=)
https://github.com/keirf/FlashFloppy/releases/download/v0.11/flashfloppy-v0.11.zip
« Yanıtla #53 : Kasım 02, 2018, 00:26:16 ÖÖ »
Yuh, ne çabuk yenisi çıktı.
Mesaj Sayısı: 5.194
« Yanıtla #54 : Kasım 02, 2018, 08:17:47 ÖÖ »
Belediye çalışıyor
Mesaj Sayısı: 5.194
« Yanıtla #55 : Kasım 27, 2018, 18:12:09 ÖS »
v0.12
Release Notes:
IMG: Support Nascom 1 & 2 (host=nascom)
Direct Access: Support FM/SD access on cylinder 254
Direct Access: Support CMD_SELECT_IMAGE (cmd #4)
HxC Compat: Fix occasional "LBA Change Test Failed" error
Improvements to ribbon-upside-down checks
https://github.com/keirf/FlashFloppy/releases/download/v0.12/flashfloppy-v0.12.zip
Mathman
Mesaj Sayısı: 1.252
AmigaOS System Specialist
« Yanıtla #56 : Kasım 27, 2018, 18:50:08 ÖS »
bu güncellemeleri nasıl yapıyoruz?
           M A T H M A N
       Re-Amiga 1200 !!!
« Yanıtla #57 : Kasım 27, 2018, 19:09:51 ÖS »
Paket içinde FF_Gotek-v0.12.upd dosyasını flash diskin kök klasörüne atın. Başka bir .upd dosyası varsa silin.
Flash diski takıp bilgisayarı çalıştırmadan önce, gotek düğmelerinin ikisine beraber basılı tutun ve bilgisayarı çalıştırın.
Flash ve update yazılarından sonra işlem tamam
Mathman
Mesaj Sayısı: 1.252
« Yanıtla #58 : Kasım 27, 2018, 19:35:22 ÖS »
Direkt en son güncellemeyi yapmamız yeterli mi?
Yoksa tüm güncellemeleri en baştan itibaren mi yapmamız gerekiyor?
           M A T H M A N
       Re-Amiga 1200 !!!
« Yanıtla #59 : Kasım 27, 2018, 19:43:38 ÖS »
son güncelleme yeterli. Yeter ki gotek flashfloppy firmware olsun..
Sayfa: 1 2 3 [4] 5 6 ... 16   Yukarı git
