commodore.gen.trAmigaAmiga DonanımFlashFloppy yeni gotek firmware
Sayfa: 1 ... 5 6 [7] 8 9 ... 16   Aşağı git
Gönderen Konu: FlashFloppy yeni gotek firmware  (Okunma Sayısı 187818 defa)
misket
Mesaj Sayısı: 294
« Yanıtla #90 : Nisan 15, 2019, 09:40:22 ÖÖ »
Aaa kaçırmışım, ben de bekliyorum
Teşekkürler
« Yanıtla #91 : Nisan 25, 2019, 22:32:34 ÖS »
v2.7a
Sort folders into alphabetical order during direct navigation
FF.CFG: folder-sort= to modify this new default behaviour
Fix memory corruption issues (stack overflow)
ATR: Interleave sectors for best performance over slow SIO interface
https://github.com/keirf/FlashFloppy/releases/download/v2.7a/flashfloppy-v2.7a.zip
Mesaj Sayısı: 2.751
« Yanıtla #92 : Nisan 25, 2019, 23:05:19 ÖS »
v2 firmware'ler development branch'iydi değil mi?
« Yanıtla #93 : Mayıs 10, 2019, 17:46:46 ÖS »
v2.8a (Experimental)
DSK, IMG: Fix small error in generated MFM data
Increase write buffer to 32kB, enough for a full high-density track
More reliable whole-track writes and disk formatting, especially to HFE images
https://github.com/keirf/FlashFloppy/releases/download/v2.8a/flashfloppy-v2.8a.zip
Mesaj Sayısı: 2.207
« Yanıtla #94 : Mayıs 10, 2019, 22:46:21 ÖS »
Adamlar durmuyor, neredeyse haftada bir guncelleme var. Biraz beklesinler de kullanalim yahu 🤣
« Yanıtla #95 : Mayıs 24, 2019, 10:20:42 ÖÖ »
v2.11a (Experimental)
Simpler bootloader update process with all-in-one update file
Update firmware via SD card as alternative to USB (on enhanced Goteks with SD card slot)
FF.CFG: sort-priority= to prioritise folders vs files during navigation
Default: Folders are listed before files
https://github.com/keirf/FlashFloppy/releases/download/v2.11a/flashfloppy-v2.11a.zip
« Yanıtla #96 : Mayıs 27, 2019, 08:06:23 ÖÖ »
v1.3 (Stable)
Indexed mode: Fix for *.ST images
MFM generation: Fix small error for DSK and IMG
https://github.com/keirf/FlashFloppy/releases/download/v1.3/flashfloppy-v1.3.zip
Mesaj Sayısı: 2.751
« Yanıtla #97 : Mayıs 27, 2019, 09:16:13 ÖÖ »
Oo yeni stable çıkmış, SD-35'e kurayım
« Yanıtla #98 : Haziran 05, 2019, 14:06:17 ÖS »
v2.12 (Stable)
HFEv3: Support flaky/weak bytes
LCD/OLED: Improve power-on initialisation robustness
Roland: Direct support for *.OUT images
IO-Test: New alternative firmware to test Gotek I/O pins
https://github.com/keirf/FlashFloppy/wiki/Testing-IO-Pins
https://github.com/keirf/FlashFloppy/releases/download/v2.12/flashfloppy-v2.12.zip
v3.0a (Experimental): To Be Announced
Mesaj Sayısı: 4.063
« Yanıtla #99 : Haziran 05, 2019, 19:01:04 ÖS »
Stable V2.xx lere geçtik demek, adam durmadan çalışıyor
Teşekkürler Kaan.
« Yanıtla #100 : Haziran 07, 2019, 12:10:08 ÖS »
v2.13 (Stable)
HFE: Fix read buffering error
Update HxC Compat to v6-FF
More robust error checking on writes
https://github.com/keirf/FlashFloppy/releases/download/v2.13/flashfloppy-v2.13.zip
Mesaj Sayısı: 2.751
« Yanıtla #101 : Haziran 11, 2019, 13:13:13 ÖS »
Akşama SD-35'i update edeyim
« Yanıtla #102 : Haziran 11, 2019, 13:14:07 ÖS »
Disk Change Reset: Emulate explicit Reset signal of certain vintage drives
Requires a hardware modification and FF.CFG: chgrst=pa14
Support ZHONGJY_TECH 2.23" 128x32 displays based on SSD1305 controller
FF.CFG: display-type=oled-128x32-ztech
https://github.com/keirf/FlashFloppy/releases/download/v3.0a/flashfloppy-v3.0a.zip
« Yanıtla #103 : Haziran 13, 2019, 12:31:41 ÖS »
v3.1a (Experimental)
OLED: Text height and content can be configured (FF.CFG:oled-text=)
New default for 128x64 displays presents a new third text row
LCD/OLED: Present an action menu when an image is ejected
Includes Clone and Delete Image operations
https://github.com/keirf/FlashFloppy/releases/download/v3.1a/flashfloppy-v3.1a.zip
Exu
Mesaj Sayısı: 445
« Yanıtla #104 : Haziran 20, 2019, 00:02:32 ÖÖ »
Gotek 2.13 yükledim ama 1200 şimdi görmüyor. bios ekranında da DF1'i göremiyorum. Açılışta gotek çalışıyor ve firmvire 2.13 yazısı görünüyor. ne yapmalıyım?
Sayfa: 1 ... 5 6 [7] 8 9 ... 16   Yukarı git
